Went to GoOutdoors the other day and the quality of all the footwear seems poor these days.
Lots of rough looking glue around the soles.
I was all set to try a pair of Solomon shoes but they looked and felt like they'd only last a few walks.
'Climb' is stretching things a bit for Snowdon....Boots wise, still very happy with my Altberg pair, only downsize is the weight.
Finally ticked Snowdon off at the weekend too, can't say it felt like a particularly amazing climb but then again I might be a little spoilt coming off the Carpathian mountains in Romania.
you use walking poles for descents especially ? I got some thin sorbothane insoles for mountain boots and use thicker version to replace those in running shoes,In other news, think my knee is getting sorted now with new inserts provided by the podiatrist. Hoping to start working towards ML again
are they insulated - some fleecy inside .. still looking to replace some polartec type trousers (sprayway) that are worn to death especially around harness, but don't inhibit movement,Treated myself to some Mountain Equipment kinesis trousers to go with the jacket I got a while back
Yeah they're insulated, a soft fleecy lining, windproof DWR outer. Stretchy, light....big step up from the Montane Terra Mission I had before....which are still decent, but don't breathe as well, weigh twice as much, and don't stretch.are they insulated - some fleecy inside .. still looking to replace some polartec type trousers (sprayway) that are worn to death especially around harness, but don't inhibit movement,
powerflex tights are a bit too tighty.
www.mountain-equipment.co.uk
they are four season apparently ? for fixed crampons, scarpa invernos I have wouldn't be too comfortable on a jaunt up snowdon.my biggest ever mistake was getting some Mantas that felt alright...
Yeah I wore them a few times when doing winter hikes, they're a B2 boot.they are four season apparently ? for fixed crampons, scarpa invernos I have wouldn't be too comfortable on a jaunt up snowdon.
Scarpa running shoes - hmmh did consider north face / scarpa trail shoes for the vibram aspect, but the cushioning versus my Asics was an unknown, as an approach shoe probably good.
I don't know if other brands are as effective.
I would also recommended poles. It only takes a couple of outings to get used to them in my experience, and I would not be without them now. Really help take a bit of the impact out of downhill bits, as well as helping propel you uphill, balance on loose ground and crossing streams etc.I need to get some walking poles and stop thinking it makes me a lesser walker!
Off to Scotland next week, few days in the Cairngorms, then over to Skye, using hostels and club huts (then my folks place). Hoping to do lots of big mountain multi-pitch climbs, but if it's too cold then just sticking to mountaineering routes.
Been waiting for some big mountain time all summer, can't wait. Treated myself to some Mountain Equipment kinesis trousers to go with the jacket I got a while back, I am a total convert to soft-shell gear, makes such a huge difference when you're working hard to not get sweated up, and the latest fabrics can take a hell of a soaking before you get wet.
I had the same. luckily I wore mine in the snow as after 5km they wrecked both my heels. The problem is a lot of places don't stock half sizes so if you're between then it's really an expensive foot killer.Tried a few Scarpa and didn't like them at all, my biggest ever mistake was getting some Mantas that felt alright in the shop and arrive the house. But horrendous after a few hours of hiking.
Mammut seem to fit my feet well so far. It's a pain getting new shoes/boots. Always a risk they'll be issues after a few hours.
I've been in some cold environments and I've always just used base layer bottoms, with pants like ME ibex or montane terra over the top, and rab firewall overtrousers over them to offer the best flexability. I find my legs don't get as hot, and you can be a lot more flexible then. fleesy pants I end up sweating in, are a lot heavier and bulier, so don't pack as well.you use walking poles for descents especially ? I got some thin sorbothane insoles for mountain boots and use thicker version to replace those in running shoes,
