Will let you know when mine is dispatched![]()
Eh, in 2020, websites were crashing just trying to get into them. And if you were on the web page, nothing was responding.My payment went in then nothing and nothing at all. This is the same.
Thanks, it has a BIOS switch, so make sure you set it to the performance BIOS and you might need to download Zotac's overclocking tool to properly test the card.
Hoping the Zotac amp can do 600W
I have OLED 175Hz (Alienware) and I can definitely see tearing if I run out of refresh rate. I have always used vsync with Freesync and G-Sync, because it does nothing in the range of adaptive sync (which both AMD and NVIDIA confirmed many times) and it only kicks in when you go outside range (working as frame limiter). Though if you enable low latency in NVIDIA drivers or Reflex in game, it will cap your FPS even below that (167FPS in my case max instead of 175Hz), just to be sure you never spike outside refresh rate and vsync never kicks in.I found his take on vsync really interesting that I figured would be worth mentioning here.
1:
No matter what, I have always found that enabling vsync in pretty much any game introduces mouse movement latency, that elasticy effect you see when moving the mouse around quickly. Some people get used to this, and I did too for a stretch when I was on a 60Hz monitor with no VRR, but now that I have a VRR monitor up to 175Hz and with Gsync Ultimate, I only have Gsync enabled in NVCP, and have not forced vsync on in the global setting there. I also leave Vsync off in all games, I have yet to see any tearing whatsoever whether the game is running under or over my framerate target, which is either 120fps or 144fps since my monitor is in 144Hz mode (10-bit colour vs the 175Hz in 8-bit).
Games like FDays Gone I have to choose 120fps target because the preset slider is not granular, it goes from 120 fps to 150 for example, so I settled on 120. If I set it to unlimited and let it run at any fps it wants, then it could be 150, 170, 165 fps etc - In these situations I still see no tearing, just a nice and smooth motion. I lock it to a comfortable 120fps because the GPU caps don't whine as much then and the GPU fan doesn't run as loud.
2:
So what's going on here, why am I not seeing any tearing? is it because my monitor is an OLED and the nature of OLED motion means any tearing you would normally see on an IPS-LCD is removed?
3:
Is it because it is Gsync Ultimate?
4:
Is it a combo of both 2 and 3?
It's an intriguing one, I have tested with a bunch of setting configurations in a whole host of games since getting this monitor and no tearing is observed in anything whilst leaving Vsync off, but leaving Gsync enabled and letting the Gsync Ultimate module do what it needs to do.
This sort of thing doesn't really get clarified much on technically geared videos or reviews so I've observed this thing and am asking myself what's going on, even though I see no problem (tearing), so am not too fussed either way lol.
This been posted? Quite insightful.
aha well I kinda hate that guy. TBH very few cards are worth more than the FE, but it's going to be scarce for monthsWell Jay2braincellz says the strix isn't worth it, but in the same video he mentioned it being a PCIE gen 5 card, which it isnt so![]()
Drops for the 3000 series were Tuesday and Friday but not regularly enough to become consistent.No FE restock at all today? Interesting... wonder when UK will get more.
Anyone had a Zotac Amp shipped yet?
Yup, my Airo Amp has shipped. (the order went through at 14.07pm fwiw).Anyone had a Zotac Amp shipped yet?
