If I was going for an M2 then I think I’d buy the previous gen Comp instead of this.
Looks better than the leak but still not sure about it. Looks ok from some angles and weird from others. Maybe it will look nicer over time like the M3 and M4
Yes pretty much every review of the G80 and G82 says it completely hides its weight, I would drive one before passing judgement.1725kg. Come on. They're not even trying anymore are they, it's got the same bloody engine! BMW slowly doing a Citroen in front of our very eyes.
YesSomething I noticed more than how dividing the look of the car is, was, if you youtube it, every single youtuber has a video up of exactly the same thing. Do they all just line up at the press event and get their 20 min slot?
Those dash dials look absolutely pathetic lol. Like someone has glued a TV with no forethought and then some dodgy support bar to hold them up.
RIP BMW
Their EVs look worse lolThat M2 is hideous, looks like a poor attempt at a Max Power special, I honestly believe BMW are purposely making their ICE cars look hideous so their EVs will look acceptable
Looks like something out of starwars![]()
Yes, M Performance Parts section at your nearest dealer will stick the tat on for your new M2.
Looks like you have a mismatch on recommended sizes.
I'd go with 2.4 all around though.
What year and model? I'd agree with Dis86 that something looks wrong given your configuration doesn't match the label applied to the car.They are the factory spec staggered M Sport setup.
