Poll: ** The official 2022 Apple TV 4K thread (it has the A15 chip, HDR10+ and everything!) **
Are you going to buy the 2022 Apple TV with USB-C charging on the remote?
  • Total voters
    53
Commissario
16 Oct 2002
In the radio shack
There's a new Apple TV - It has the A15 chip, HDR10+ and the remote has a USB-C port for charging.
What's new with the latest Apple TV (shamelessly copied from Macrumors):
  • A15 Bionic chip: The new Apple TV is equipped with the A15 Bionic chip for up to 50% faster performance than the previous model with the A12 Bionic chip. Apple says this results in improved responsiveness and faster navigation. Apple adds that graphics performance is up to 30% faster for smoother gaming.
  • 4GB of RAM: The new Apple TV is equipped with 4GB of RAM, compared to 3GB in the previous model, for improved responsiveness.
  • 128GB storage option: The new Apple TV is available with up to 128GB of storage, compared to a max of 64GB for the previous model.
  • HDR10+ support: In addition to Dolby Vision, the new Apple TV now supports HDR10+ content in supported apps.
  • Siri Remote with USB-C port: The new Siri Remote is equipped with a USB-C port instead of Lightning for charging.
  • Thinner and lighter design: Apple says the A15 Bionic chip's increased power efficiency allowed for the internal fan to be removed in the new Apple TV, resulting in the device having a more compact design that is around 12% thinner and around 50% lighter than the previous model.
  • No more "TV" branding on top: The new Apple TV no longer has "TV" imprinted on the top of the device and instead simply has a centered Apple logo.
  • Lower pricing: The new Apple TV starts at $129 with 64GB of storage, while the previous model started at $179 with 32GB of storage. While you need to spend $149 to get an Ethernet port, Thread support, and 128GB of storage, that's still cheaper than any of last year's models.
  • No charging cable in the box: The new Apple TV ships without a charging cable in the box for the Siri Remote, except in Brazil. Apple sells a new woven USB-C cable separately for $19.
  • Packaging changes: The new Apple TV comes in a slightly more rectangular box that no longer has outer plastic wrap.
7 May 2012
64gb is Wi-Fi only and is £149.00, 128gb is Wi-Fi and Ethernet and is £169.00
If you can get last years model I'd suggest getting that instead.
Commissario
OP
16 Oct 2002
In the radio shack
£149/£169 for the 64Gb/128Gb versions. The £149 model doesn't come with an ethernet port though.
I'm pretty sure I've never driven my 2021 version hard at all and I've certainly never used much storage. I'm not sure about this. Last year it was a no brainer as the previous version struggled with some very high bit rate HEVC video but the 2021 doesn't skip a beat.
7 May 2012
If you've got last years model then there is no reason to get this new version. Hell, the two 2017 ATV 4K's we've got in the house upstairs are just as fast.
1 Nov 2002
Sussex
It’s annoying that you have to pay more for Ethernet. I’m not bothered about the 128GB, 64 is plenty for me. HDR10+ support is useful just kind of annoyed about that Ethernet.
