Yep same as mine , poor CPU is choked to death
Honestly, was expecting the 10900k at those clocks to beat out the 5900XYep same as mine , poor CPU is choked to death
10900K @ 5.3Ghz
4090 @ 3135Mhz / 6001Mhz
pretty good gpu clocks though. Mine starts to freak out at 3060mhzYeah 10900K is a bit old now , eyeing up a 13900k in a few weeks time although i wouldn't mind waiting till next year when 14th gen is out so i at least get a bit longer on the new socket or may even look at AMD with the 3D versions of the 7000 series cpu , decisions decisionsHonestly, was expecting the 10900k at those clocks to beat out the 5900Xpretty good gpu clocks though. Mine starts to freak out at 3060mhz
Good spot , didn't notice that... maybe the 10900k isn't so bad after alli dont mean to rain on your parade but was 8xaa enabled, i dont see it in your screenshot?, those 4090 scores are mighty impressive never the less
Good question to be honest guys, my bad if I didn't spot it. I'll rerun/double check when I get home todayThis is not for the score board but this is what a 10900k gets using the same settings without 8xAA
AMD Ryzen 7 5800x at stock speeds
Founders 3060TI at stock (reporting as GPU 1410, Memory 1750)
Nvidia drivers 522.25.
Score seems a bit low compared to similar systems. But I only just built this PC
Apologies, I have updated my screenshot with a new result (a few points less, too)For the scoreboard we need the results shot over the cobblestones.
