- 5 Jun 2007
- extremes.spacious.indelible
Look at van conversion on youtube, lots of stuff out there and the theory will be the same.
Greg Virgoe is the godfather for insulation, check him out.
Airflow and ventilation is your friend, we as humans give off a HUGE amount of moisture.
A vapour barrier and then celotex sheet insulation will probably be the way to go, as thick as you possibly can without losing too much living space.
When properly insulated it should help it stay cool in the summer and warm in the winter.
