A few hours ago Galax released some of their internal testing on the 16 to 4x8 pin adaptors that come with their 4090 cards. They hooked it up to a commercial power supply unit to artificially pump more power through it.
They say they pushed 1500w through the adaptor and they did the test with the cables straight and bent. What they observed was a significant increase in temperature when the cable was bent, however the temperature was still well within spec and not enough to melt the connector.
Because of this they believe those with burnt connectors is either some sort of manufacturing failure that's quite rare causing some pins to not be making proper contact or the user is simply not pressing the connector deep enough into the GPU pcie power pins, causing additional heat resistance.
They decided to test the latter and they found when they pull the connector slightly out of the GPU but still enough to make contact, the GPU would work ok but the connector would reach 100c
