Is anyone using a Unifi device as a Mesh? I have a UDR, and the wifi does not reach the upper floor (to be expected I guess). My plan was to buy an AP and put it somewhere between the UDR and upstairs and Mesh them and then hopefully have good wifi upstairs. I have 1GB and I no way need that much or expect to get that upstairs! Even if I got 200Mbps I would be fine with that, at the moment its barely 10Mbps and very flakey upstairs. Rented apartment so not much I can do about the walls or whatever else is causing the signal to degrade!
At a later date I MAY wire the second AP, once I nail down a good position for it, but for now just wanted to get a POE injector and then plug it in in various locations around the flat and find a good spot for better coverage.
Any thoughts or advice?
I am considering the below 3 and I don't wish to spend any more than these cost!:
Compact, ceiling-mounted WiFi 6 AP with 4 spatial streams ideal for smaller offices.
eu.store.ui.com
Sleek, indoor/outdoor WiFi 6 AP with 6 spatial streams designed for mesh applications.
eu.store.ui.com
Ceiling-mounted WiFi 6 AP with 8 spatial streams and extended signal range.
eu.store.ui.com
rp2000
