Sure fire way to ensure it will 100% fit, even if it was a mini, it would have fitted!
Oh, I wasn't giving up until it was in
I'm going through a similar challenge on the homefront at the moment, tooOh, I wasn't giving up until it was in![]()
Nothing in house wiring is connected in series, I think you need to carefully put things back how they were :OSuperb man task today. The switch for the Oven has broken, it's located in a cupboard which is very full, so naturally i've squashed myself into it to replace. After lots of cursing because the screwdrivers i could find would barely fit, i finally managed to get it replaced.
Switched the fuse back on and it seems i've now broken the microwave which is powered by a socket elsewhere in the cupboard. I initially thought i'd not connected a wire up, but i'm also fairly sure that assuming it's a ring main then it wouldn't complete the circuit. I'm hoping it's all just wired in series and simple a loose wire.
Either way i got fed up and figured we just need to not use the microwave for a while.
That's a big area. We're you the one with ufh earlier? Also, random comment but didn't know you could get sliding doors that eide, it's like a small hangerGot the joists and steel down, to create our vaulted kitchen ceiling with mezzanine level to look out over the pool and surrounding area - floors has been screeded and sliding doors installed too since last update
Should be nice and toasty with that setup. I do think radiators are a poor way of heating houses. Ufh heats a room evenly, just requires a bit of common sense to use (not like at my local leisure centre that thinks it's instant. When I take my kids swimming, I was sweating in a t-shirt it was that warm).Yep, that was me/us!
The sliders are 6m total width, split in to 3 x 2m panes - they slide from either side so can be stacked either side of the opening, or all sat in the middle 2m section.
Still waiting on the triangular pitched window above, which unfortunately doesn't look like it'll be fitted much before Christmas![]()
Should be, when our heat source is finally installed! Waiting until end of November at the earliest to have the ASHP installed - can't wait to start force drying the screed and getting some warmth in to the house!
Yeah, and well, it's where it needs to be to stop the water in the shed. It isn't a perm fix, as I voice over in the main thread, the whole ramp/patio etc needs digging out. I'm pained to do it in case I extend in the next 5 years tho....however 5 years is a long time...Is it close enough to the boundary fence to catch the puddle that appears there at times?
You might find you need to reduce your flow. I fitting a waterfall one to my downstairs toilet sink (which is narrow), and as the water comes out the front rather than underneath there is a bit more splashing. There's isolators on the hot and cold though so I've reduced it that way.Fitted a new tap. Old one was a pig to remove due to odd copper spacer pipes between the flex hose and the isolation valves as well as the retaining bracket using a hex screw, which I then dropped the screw bit for down the space at the back, never to be seen again! Thankfully it was loose enough at that stage I could get it out.
