NVIDIA RTX 3090ti Stock
The TUF OC one
standard..sent you private message..dif betw oc and standard card s are minimal in my view..just look at review..maybe a few fps diff seems to me... but it's brand new and the tuf card, so identical in looks to the oc card
what are the other components you have that a 4090 wont fit? the 011dXL isn't exactly a small case
Thats great info, shame 3090ti is too powerfull for 1440p...
Where are you getting this false information from ? There's no such thing as too powerful.
3090Ti running 2 different games.
Assassins Creed Valhalla at 1440P max settings, GPU usage hovers around 97-99% with FPS around 120.
Cyberpunk at 1440P max settings, GPU usage hovers around 95-99%, FPS around 80 with DLSS set to Quality.
Also don't understand why you'd spend near £1600 on a 3090Ti when that is near enough how much the 4090 FE costs which would get you even more performance, If you have the PSU to run a 3090Ti you can run a 4090 and if you have a LianLi 011DXL you have a LOT of room for the 4090.
Getting a 3090Ti at this pioint for near £1600 is highly illogical, I'd only get a 3090Ti if like me you managed to get it substantially cheaper than the 4090 otherwise it's very silly spending that amount of money on a last gen product.
What's difference in FPS in 1440p games in 3080ti and 3090ti please?
As far as I know 3080ti is best £/performance for 1440p. All I'm looking for is 120+fps on latest games in 1440p.
I never said I would buy 3090ti anyway - waste of money for me.
it doesnt matter what the diff in fps is, you said its too powerfull for 1440p but it cant even do 144-165 fps max settings on those 2 titles he tested, so its only too powerfull for 1440p if you turn settings down so then its not is it, thats the point he is putting across, nothing to do with value or performance/£
I see what you doing - trying to get me to spend more money xD
Sell me even rtgtx 5095 for max £500 then ;)
EDIT: just checked and difference between 3080ti and 3090ti in Assasins Creed Valhalla on 1440p is 5-7FPS difference. And cyberpunk as a reference? No comments here... May as well bring Mario bros to conversation.
Are you guys serious? Do you really suggesting anybody to pay so much extra for few FPS? MASSIVE XD
You said and I quote "All I'm looking for is 120+fps on latest games in 1440p." now the difference between the 3080Ti and 3090Ti isn't just raw FPS, Which depending on the game can actually be a difference of 20FPS in some scenarios, But also perceived smoothness ingame which I've tested myself and the difference is there.
If you want 120FPS in the latest games at 1440P then you need the best there is which right now is either the 3090Ti or 4090 OR you can wait for the 4080 16GB or even AMD's 7900XT/XTX and see what the performance is like for the latest games at 1440P.
I'm not talking about games optimized by * * * << put here whatever you want.
I've watched pretty much all yt videos related to performance in latest games and if you think you need more than 3080ti which is best £/performance then you need to see more competent GP you seeing now.
You created a thread looking to buy a Strix 3090Ti and now you're arguing against a 3090Ti, Give your head a wobble lad :cry:
My apologies, Just glanced the profile picture :D
Another reason why I have been wishing for years we could have proper custom profile pics like every other forum in existence.
I had that problem, it makes it easier if you just disable profile pictures in your settings.
