- 22 Mar 2017
- Poland
just was testing
No one knows, just uninstall the game and play Tomb Raider.So that person ( from youtube ) have on the same place 110-120 fps and 80-90% usage. Why i have 90-100fps and gpu usage 50%and less fps fps than 12700K and 3080 ti on the same settings. Its - > 1080P Rt ultra,dlss performance
I dont use DDU when installing new drivers. I just update it. Maybe thats why dlss is screwed?
yes it is normalDid you ever sort out the quake issue?
Its the game again. I found someone with Rtx 4090 and 12700K. On 4k but he plays with DLSS settings and no fps change between DLSS modes. Link:\
( its spanish but you will easy understand
So why that happens its driver issue or what? Look at usage its so low. I am gettin the same 50-60% lol.
Metro Exodus: Enhanced Edition | RTX 4090 + i7-12700K | Extreme Settings [4K TEST]
pics or didnt happen, my mate has a Polish wife.
Cause you are cpu and memory bottlenecked. How many times do i need to repeat myself. A properly setup 12900k should never drop below 120 fps in cyberpunk 2077 no matter what, 120 is the lowest it goes at the hardest areas of the map. Jesus Lord stop asking things that have been answered.O tried Metro Exodus EE and the same situation. DLSS is not giving more fps only gpu usage going lower. Any ideas?
Is it gpu bound? If it is then yeah, obviously it will drop, im saying the drops should not be happening cause of the cpu if you have proper rameven on 13900K dropping to 80-90fps on 1440 with dlss quality. Look
Its not the ram. ThxIs it gpu bound? If it is then yeah, obviously it will drop, im saying the drops should not be happening cause of the cpu if you have proper ram
