- 14 Apr 2014
- Hampshire
I got a cheap one from IKEA and it can't support the weight of two monitors and my laptop. The motors have already given up
Only thing is the desktop comes as 2 halves that you put together, so you get a line through the desk where it joins together.
you could just purchase the frame and then slap whatever table top you like.
Plus if you're getting a standing desk I don't see why you'd go the extra step to not have to wind a lever.
I have a fully Jarvis, not one I could consider 'cheap' but not the dearest either.
The one thing I don't like about it, either up or down - is that it's not as stable as the fixed desk I had before it. It 'wobbles' a bit, which I don't like. I have 2 screens mounted on monitor arms, so they wobble with it. I think if I had smaller screens on their stands it wouldn't be as bad. Possibly if I was on a carpeted floor, or concrete floor (instead of laminate & floorboards) it might be more stable, so I don't think it's all down to the desk.
I'd recommend trying before you buy if you can. I also find I don't use it standing as much as I should.
Very daft question but I assume you can set the Fully desks to any height between the stated ranges, not just the very top or the very bottom? I was a bit confused by the terminology of "2 stage" or "3 stage" heights.
How has the wobble issue worked out for you?
Yes, I have a fully jarvis desk with a 32" monitor and can set whatever height you like or lower it incrementally and stop pressing it. For my one I don't find it wobbles too much.
Old pic with previous monitor below
Mine is 1.8m, initially I bought 1.4m but they upgraded me for free as the delivery was quite delayed (during lockdown)Cheers, I’m looking at an upgrade to my current £50 John Lewis desk that I’ve had for 7 years!
What width did you go for?
Oh yeah, if you're over 6 foot I'd consider getting the "3 stage" one which can go slightly higher but I tend to like a high standing desk, I'm about 6'1.Cheers, I’m looking at an upgrade to my current £50 John Lewis desk that I’ve had for 7 years!
Pushing this post back up to see if anyone has other recommendations for standing desks. I would need to buy two so ideally want to keep each one around £250 - £300 max.
Has anybody noticed any differences / Benefits within themselves after moving to a standing desk?
