Glad it wasn't me who just saw that.did we really need to see your butt plug![]()
The Halloween / Christmas decorations don't seem to mind. Haven't checked on the hamster for a few months though. I'm sure it's fine.No issues with plastic boxes not being breathable?
Also in-between jobs I finally put my soul at peace:
Zoom in and all three pretty much are lol.Which one is (or will eventually will be) the junk drawer? Everyone has a junk drawer!
They've got gelatin in for some reason, so not veganDid you try one?
zoom in on third drawer from top right and it is full of used syringes. He is already at it.Which one is (or will eventually will be) the junk drawer? Everyone has a junk drawer!
I had to Google Calpol - never heard of it before. - We are child free though.Surely everyone has a drawer full of old Calpol syringes.
I used to like plumbing now I really hate it.My two isolating valves with lever on are coming tomorrow so been under the sink and turned mains valve off and on then opened the system drain valve to let water drain from pipes through a piece of permanent hose pipe on drain valve just going through the wall.
Checked the tube of Fenex sealer to see if it's soft and it is, so now all ready to go. Changing the outside tap isolator valve which has siezed in open possition.
Much less cussing when I do the job.
It's magic.I had to Google Calpol - never heard of it before. - We are child free though.![]()
That is my main gripe for plumbing jobs, I'm 36 but I've been doing practical jobs since 16 and whenever I do plumbing it's majes my knees ache, and generally the job involves either seeing it or doing it, just not both at the same timeI used to like plumbing now I really hate it.
Isolating valves never arrived so in end got refund from Ebay then got two from Screwfix.
Installed myself under the sink - took everything off including waste pipes and couldn't get old isolating valve out due to tightness of pipe -just above a 90deg throught wall and 6" below the pipe went into a horizontal pipe - in the end it was cut pipes and put the two valves on (didn't have a straight compression connector) With these two valves on you have wiggle room to get pipe and olives on - Got them on and tightened them up -turned on water and a slight leak from top joint due to it being the top joint on old valve so the old olive and nut was used.
Next day cleaned up joint and put loads of Fenox around joint and tightened it up real tight -
So far 24hrs later still water tight .
I now loath and detest plumbing - my knees and neck still ache but at least I can turn off outside tap supply.
I just have this feeling we are in for a cold winter.
