*** Official Ubiquiti Discussion Thread ***
I seems the code use for the UDM-Pro to force a 1500 MTU, still doesn't work so i'll pick it apart and work out what's needed.
Code:
sed -i 's/ 1492/ 1500/g' /etc/ppp/peers/ppp0
ip link set dev eth8 mtu 1508
ifconfig eth8 down && ifconfig eth8 up
killall pppd
Even though its the same hardware, it does feel snapper.
Kenable and Cable Monkey are usually recommended on here.
My last box was CCS from cable monkey, no complaints but I can’t exactly say I am an expert.
Cheers. Heard of kenable and Connectix, was looking at Connectix
CCS is Connectix Cable Services and they are Cable Monkey in the UK (they have the same address anyway). Excel is another quality brand that you often see as BT or Openreach branded.
Hi RX frames on an AP after an update on firmware. Anyone else experienced this with 6.2.39? RX frames on 2.4Ghz band.
Did a RF scan and no data for 24
Rolled firmware back and issue goes away?
I haven’t checked for a while and I was a bit shocked to see that my U6-Mesh and U6-IW units are showing 6.2.39 while my U6-Pro, U6-LR, U6-Enterprise are showing 6.2.44 and the U6-Enterprise IWs are showing Beta 6.2.47. I’m on the stable release channel only except for EA kit that obviously needs Beta firmware. I manually update my firmware, minimum of 7 days after it has gone out to stable release to let the early adopters tell me if it’s good or not.
And no, no issues for me on 6.2.39 but if it’s not there in 6.2.37 then I strongly suspect it’s a bug.
Interestingly, one of the bug fixes in 6.2.44 is it fixes an issue with reporting incorrectly ‘high number of TX retries’ in Gen2 access points so it probably is a bug.
I was just looking at that myself last night, I upgraded to that and no change. Essentially clients stop connecting to the unit and 5ghz is randomly disabled.
Rolled back to 6.2.16 and problems go away.
So i've got 2 unifi AC Lite which covers the house fine. But find now we have so many wifi devices performance seems to pause quite a bit... I only have 50mb internet at the moment.
Is it worth upgrading to U6-Pro's ?
Pretty sure its auto on most settings and yes both are hard wired.
And yeah I have a load of IOT devices....
hue bulbs
cameras
iphones
ipads
macbooks
tv
fridge :rolleyes:
Alexa's
etc
Ah I do have a spare AP AC lite :p
So create a separate SSID for phones / laptops on a specific AP should help ?
I have a separate IOT network with a separate SSID, I force IOT type devices to one of the APs which frees up the other for my laptops/phones etc. No idea if this is best practice or not but it works well. I also use a bandwidth limitation on this group.
There's also a way you can lock clients to use a specific AP.
