Home Assistant
25 Oct 2006
*reviving meter discussion*
looks like there is a commercial reasonably priced solution now
which folks have integrated, could be my first post brexit aliexpress purchase
finally get some high precision data
That looks cool... I actually bought an optical reader with an ESP8266 attached to try read mine but I'm not getting much back...
https://www.ebay.com/itm/313460034498 like this
ttps://tasmota.github.io/docs/Smart-Meter-Interface
I can only get back "/HTc5 RTC2 ISSUE 1.1". Google proved less than useful.
OP
5 Mar 2010
Any idea how InfluxDB getting too big corrupts the backup?
Not a clue tbh!
IIRC when I looked a bit more at the database mine was about 40Gb in size. So I do wonder if during the compression phase it's hitting some sort of timer and is killed before the compression has completed.
1 Mar 2010
OK that's not a bad price ... seems he has a video too linked from ebay
to post some feedback
ESP can be run off of battery pack too, my meter is a couple of meters outside door, so I would be hoping I can open up the TUYA/220v one and introduce my own supply.
25 Oct 2006
Yeah unfortunately mine is also outside. I ran that reader (albeit in warmer climate than now) the other week for 4 days or so on a 21500mah Anker power bank.
1 Mar 2010
ucontroller code I had looked at does have power optimization to ensure that device is in shallow sleep and only transmits occassionally,
not sure if even the blink recording didn't need a full processor wake-up, with some autonomy
25 Jul 2003
Cornwall/Bristol
So, Ive had HA running on a HP T530 mini pc only for a couple of weeks. It only came with an 8GB SATA SSD, and its now nearly full. For some reason the disk use jumped a couple of days ago 1.4GB for some reason, and now there isnt enough space for me to run the latest core update :(
So, I can try and dig into what caused the sudden jump in disk use, which will give me a bit longer usage before running into isssues again, but I'm thinking i might as well upgrade the SSD to a larger one, 256GB should be plenty. Now the question is, whats the best way to clone the existing drive and installation onto the new drive? I've got just one USB3-SATA m.2 adapter that I used with Balena Etcher to write HAOS initially, so wont be able to have both drive connected to my windows laptop. What software would I need to clone, such that I can just slot the new drive back in, turn it on, and everything on HAOS is as it was, just with 250GB more space!
28 Dec 2017
Beds
I like Paragon. Create a disk image/backup, swap drives, restore.
1 Mar 2010
how accurate/calibrated is the device?
I subsequently read a facebook comment on the non-zigbee shelly clamp product (which I think is premium/bounding versus tuya) that suggested +-10% , so yes not so good
Shelly EM is not factory calibrated device and on small loads it is quite inaccurate (loads bellow 1A or so). So in whole day cycle depending on loads yes it can accumulate to that error margin you have noticed.
etc.
hildebrand glow at £50 , which would give dynamic gas usage too looks increasingly attractive - get both your smart meter data every 30s from DCC
OP
5 Mar 2010
Personally if it was me, I'd do a fresh install, and then full restore from backup.
