I'll be doing it that way. Thermal pad on ram, keep plastic between thermal pad and blockSounds like a plan
Let us know how you get on please and that's what i would do is keep the plastic on between pad and block section![]()
At this point i am thinking use no thermal pads at all in that case even with the crap EK pads which are 3w/mk it still doesn't get hot enough .... what a crazy situation this is , last gen we would have been praying for temps this low now we want them sky high againJust did it, don't bother. Made no difference at all. Memory was slightly hotter, but I couldn't even hit +1600 this time. I don't feel comfortable either with the tape still on the pads as it will add additional pressure to the ram modules. Ill be re doing it back to how it was before.
Core looks spot on as does hot spot but yeah memory still on the low side ... honestly think no thermal pads may be what is needed even though it sounds wrong. Alternatively leave it as is as its only in extreme benchmarks it seems to have an effect. I can daily this at +1200 memory no matter the temp of the memory which is still a nice oc over stock .. it will do +1450 depending on water temp but won't do +1550 it did on airAh damn I've just assembled mine with the plastic still on!
Still bleeding air out which will take ages!
So far with 4090 FE totally stock running FurMark for over 10min now drawing 455 Watts @ 100% TDP.
Setpoint controller 10c Air to Water Delta.
Room Temp 15c
Water Temp 25c
GPU 46c
Hot Spot 53C
Memory 38C
That's with the EK provided Thermal Grizzly Hydronaut and plastic on the pads between the pad and the block.
Guess I'm happy with the core temp but obviously memory is a bit low!
My advice from what i know now is to just stick with the stock EK block , the ABP is a stunning looking bit of kit and can understand if you want to do it on looks alone but from a performance point of view is probably doing more harm than good as very likely not helping with the memory temp issue as the back of the pcb is watercooled as well as the front so hardly has any chance to build up heat and remain stable for the memory. I do plan strip this down eventually and get the pads changed to either EK pads at 3w/mk or find something with an even lower rating to try and keep some sort of heat in the memory chips , alternatively im still keen to see what they do with no thermal pads as there is so much headroom available with them technically being able to rech 110deg safelyLooking at the difficulty in getting the memory stable with the active back plate would you guys just recommend sticking with the standard waterblock? I picked up a Founders Edition yesterday so I`m looking at this thread with interest, especially with the cost of the active back plate compared to the standard waterblock.
Thanks for the reply Jay, I`ll stick with the standard block, saves a few quid tooMy advice from what i know now is to just stick with the stock EK block , the ABP is a stunning looking bit of kit and can understand if you want to do it on looks alone but from a performance point of view is probably doing more harm than good as very likely not helping with the memory temp issue as the back of the pcb is watercooled as well as the front so hardly has any chance to build up heat and remain stable for the memory. I do plan strip this down eventually and get the pads changed to either EK pads at 3w/mk or find something with an even lower rating to try and keep some sort of heat in the memory chips , alternatively im still keen to see what they do with no thermal pads as there is so much headroom available with them technically being able to rech 110deg safely![]()
The standard block is more than enough on these 4090 , i was initially in 2 minds if to go fr the ABP or not knowing full well it had no ram chips on the back to cool but will openly admit the main factor was looks for me as i previously had a 3090 Strix with ABP and loved the look and design and wanted to replicate that again so went with the ABP for looks alone with the hope it may offer better cooling , well we now know it looks stunning but is a pita for overcooling the card somewhat , what a bizarre generation this isThanks for the reply Jay, I`ll stick with the standard block, saves a few quid too![]()
It is a bizarre generation, who would have thought that there would also be a minimum temperature for chips to perform well.The standard block is more than enough on these 4090 , i was initially in 2 minds if to go fr the ABP or not knowing full well it had no ram chips on the back to cool but will openly admit the main factor was looks for me as i previously had a 3090 Strix with ABP and loved the look and design and wanted to replicate that again so went with the ABP for looks alone with the hope it may offer better cooling , well we now know it looks stunning but is a pita for overcooling the card somewhat , what a bizarre generation this is![]()
It must be something to do with the new 2GB modules they are now using on the 40 series compared to the 30 series using 1GB versions as they never suffered from this issue at all , in fact was the total opposite and got to damn hot as stockIt is a bizarre generation, who would have thought that there would also be a minimum temperature for chips to perform well.
It would be interesting to know if the 3090Ti had the same issue as that is when they started using these new 2GB ram modules but i suppose the card wasn't that popular and even less people watercooled them as i don't think i have seen one till this day... 40 series obviously a lot more popular so the problem was found very early on.The standard block is more than enough on these 4090 , i was initially in 2 minds if to go fr the ABP or not knowing full well it had no ram chips on the back to cool but will openly admit the main factor was looks for me as i previously had a 3090 Strix with ABP and loved the look and design and wanted to replicate that again so went with the ABP for looks alone with the hope it may offer better cooling , well we now know it looks stunning but is a pita for overcooling the card somewhat , what a bizarre generation this is![]()
Shocking. Did chilled water today had the 13900k running at all core 6ghz, 4.8 e cores with the water temp at 6C and tried to pull a quick test timespy before the pub. Could t even run 1100 ram!!
Men was 6C. Def need to sort something for benchmarking.
The back block isn't needed, ekwb is just selling it because they spent so much money on RnD for it so they will try to keep selling it
