Man of Honour
- 21 Nov 2004
Clowns as well I hear.
They were present from the start.
They'll probably tour around and turn up in one of the scooby doo vans, all pile out and get shot by their own side. I'm sure I've seen a video with some Russian singer parading around trying to raise morale, it looked and sounded very bad.Clowns as well I hear.
So the Kremlin staff are going then!Clowns as well I hear.
Russia says its deploying musicians to the front line to improve morale; also asking for the public to donate musical instruments
Ukraine: Russia to deploy musicians to front to boost morale
The new "front-line creative brigade" will consist of volunteer musicians and mobilised recruits.www.bbc.com
But they questioned whether the new brigade would actually distract troops, who have been primarily concerned about "very high casualty rates, poor leadership, pay problems, lack of equipment and ammunition, and lack of clarity about the war's objectives".
Doesn’t matter when you’re too dead to get it hard.Russian women outnumbered men already before this conflict. The remaining men are going to be neck deep in ladies shortly.
Minorities and the poor pay the price of colonial Russia, sad , very sad.
I can see these being taken out before they get anywhere near the skies, much cheaper if someone can get close and destroy them before they get a chance to kill.
I meant if they know where they are stored then they can be taken out on the ground by resistance elements in Russia.Just a quick explanation of why the AN-2 Colt isn't such an easy target -
Low speed - It's low speed means two things, 1st that it can fly very, very low, making it hard for radars to spot and 2nd modern airborne radars have a feature called a "speed gate" which removes false returns caused by fast moving items like cars, trains etc and the aircraft can easily fly at just 90kt so the low speed of the AN-2 falls into this speed gate making it "invisible" to a radar unless the radar is specifically "ungated" which adds so much extra clutter for the operator to fight through to find the actual aircraft (they'd usually try to follow roads/railway lines etc).
IR & Noise - It has a very low IR signature due to the air cooled radial engine and a very low noise signature, making it very hard for MANPAD troops to find and lock-on a modern IR guided SAM onto it which is looking for jet engine temps of around 850'c+ (older SAMs) or 200'c+ for newer IIR guided SAMs which detect the heat of a leading edge as cuts through air creating friction.
So not only is hard to see and engage on a radar but its also hard to hear, or lock-on with an IR missile which makes it sound great but why isn't it being used. Well, all those advantages would disappear against a "lower tech" enemy like Ukraine because they generally use a lot of optically aimed rapid firing cannons (23mm to 35mm usually) alongside all those modern missiles and these old cannons would easily knock out this old aircraft.
