Thanks michty_me, that is almost identical to my temps and scores, so at least we know it is working consistently!Just tried my -30 all core when gaming. No issues as such and temps still high 60's but it didn't have a random spike when launching a few things so I guess its fine.
Edit:
@Richdog , Just tried the multicore test you asked the other member to run.
Max temp 79.5deg, All core 4398Mhz Score 14457 thats with a -30 neg offset in the BIOS. I can rerun tomorrow without an offset.
Is that 4.55ghz a sustained all-core clock? That is around 150hz higher than I can get, which in the end is a tiny and insignificant amount, but interesting to note. Maybe you have good silicone.CBr23 - 83 degrees All core 4.55ghz, Score 14823, 1.236v, MSI Kombo strike level 3
I'll have to give prime a shot. Was -30 stable in gaming or did you not try it with issues on prime. I recall your previous post where you said you may try -27 but didn't see the point.
Anyone seeing issues when gaming using Kombo strike or PBO tuner? I seem to recall someone saying something about it.
Yes sustained 4.55ghz all core. Not done any tinkering just latest agesa bios, AMD drivers and enabled MSI kombostrike level 3 on the bios. Specs MSI b450 pro carbon and 32gb ddr4 3200mhz ramThanks michty_me, that is almost identical to my temps and scores, so at least we know it is working consistently!
PS: I recommending adding your specs to your sig like me, makes it easier to see what ayou are running.![]()
I've tried looking for a changelog for AGESA in the past, in typical fashion manufactures notes on what's been updated from one BIOS to another is woeful, but i always drew a blank on even finding out what the latest version of AGESA is let alone what's changed from one version to another. So does anyone have a link to some place that lists AGESA versions and maybe a changelog.Using a Alpenfohn Dolomit Premium.
I think my tightening of the HSF might be at fault. Just put in my 3700X to confirm it's working, and then I removed it - the thermal compound was spread in a much more uniform manner. Only difference being, is me tightening the HSF more.
E5640 Xeon and 2500k / 2700k user here, miss those days, clocked my E8600 XP rig pretty well to 3.9ghz with a Radeon 5870, still going strong.Nowadays for both AMD and Intel there is so little left in the tank, the extra power and temps arent worth it., Same with gfx cards now.
There is only memory where, if you have picked the right memory with the right ICs, then good gains can be made by overclocking for free.
Its all a bit boring nowadays. I started off with an Athlon xp cpu which i modded with a graphite pencil to run at 40% higher speed which is when I joined these forums. There was up to 50% to be gained for free each generation.
Nowadays you can play around for ages just to gain less than 5% in benchmarks that you cant even notice in real life.
I have the same cooler but i guess there are some other factors keeping your temps 10c lower. Your ambient is a few degrees cooler and my GPU and case size and cooling could also be a factor.@Richdog I ran 3 back to back multicore cinebench runs. My room was 18c First run was 65c second and third runs were 66.5 reported from hardware info.
All core boost 4450
This is the version of the cooler I have installed https://www.overclockers.co.uk/noctua-nh-d15s-chromax-black-cpu-cooler-140mm-hs-03r-nc.html Even though its the compatability version for tall RAM its still a chunky boi.
Hold on just a minute, a while back you weee telling folk the 5800X3D was no fasterYes sustained 4.55ghz all core. Not done any tinkering just latest agesa bios, AMD drivers and enabled MSI kombostrike level 3 on the bios. Specs MSI b450 pro carbon and 32gb ddr4 3200mhz ram
Thought I had a breakthrough there, looked like it was going to settle around 80C. Eventually jumped up to ~90C after a short Prime95 load.
Fine mate. Expected.Thought I had a breakthrough there, looked like it was going to settle around 80C. Eventually jumped up to ~90C after a short Prime95 load.
