- 6 Jan 2013
- Rollergirl
Same here, I've updated 2 systems in that way without issue.I had quite the opposite experience
Seems okay, mine's the same revision, but my single thread score is a bit lower (640~) and multi thread score higher (9600~).
I don't think CPU-Z benchmark really tells you the full picture though.
That would be very odd. What temps are you seeing? With half decent cooling you should be seeing well over 4ghz.5900x supposed to have base clock of 3.7ghz, but iv noticed at stock settings out of the box when running prime 95 sfft the all core clocks are a lot less than 3.7ghz and more around 3.4ghz. anyone else notice that or is it just me??
this one:which torture test are you running in prime95 so I can test ?
temps are around 75c on all 12 core test. put it to test 4 cores and it shoots up straight to 90c throttle point.That would be very odd. What temps are you seeing? With half decent cooling you should be seeing well over 4ghz.
this one:
ahh co will be whats throwing off the readings then. since im running full stock with no co. co will reduce power pull in return that power gets used up again for more boost clock.thats after running for a few minutes stays around 3.7ghz , I aint running it at stock I have done core optimizer per core
cinebench is around 4ghz but thats not as heavy a load as prime. prime hits the tdc hard. raising tdc seems to raise the clocks of prime and power consumption. its odd that at prime running 8 core test temps are higher and ppt is higher too than when running 12 core test which has less ppt and lower temps.That would be very odd. What temps are you seeing? With half decent cooling you should be seeing well over 4ghz.
are you able to test without co and true stock settings?
That's good. So at stock it does go below 3.7ghz in prime so thats normal i guess.
I did try curve optimiser at -10 on all cores and it boosts cinebench score a fair bit but doesnt pass core cycler testing. Even -5 is unstable in core cycler. Dunno if its worth tweaking the weakest cores with co but as it is running stock its great.
Iv done some tweaks now, raised ppt to 165w and tdp to 107a edc is at 141a, this has raised all core clocks some in cinebench and temps level off at around 80c. Although in all my testing with aida, ycruncher, prime etc etc max ppt iv seen is 163w.
Handbrake encoder with the cartoons i encode only hits and holds 100% cpu usage if i do 2 parallel encodes. Guess it's the limitation of 1080p vids. 4k would probably hit cpu more
That's a large uv with co you got there.
Which cores can you take more voltage away from? The best cores or the worst ones?
