Hello
I have the razer edition lian li 011 dynamic. Looking to water cool both gpu and cpu.
2 x 360mm radiators ideally. cpu is raptor lake i5 and gpu is gainward rtx 4090.
My plan is to have one radiator at the top in-taking cool air, then one at the bottom also in-taking cool air.
Ideally then have the 3 side fans alo in-taking cool aire to help case temps for motherboard memory etc.
Seen the distro plates you can get. side mounted ones I dont want as that would loose any fans for bringing cool air into the case.
Front ones look good, but likely mean I couldnt go 360mm radiator at the bottom (Unless anyone can suggest one).
So that may mean a pump/reservoir combo that I can attach to the bottom radiator or side raditor (Seem a lot have brackets now to let you do this).
There are so many available though so very hard to decide. I dont mind hard tubing or flexi.
Seen the watercool heat killer, thermal take, corsair etc. Any suggestions or thoughts?
Thanks
Thanks
