- 5 Aug 2017
- Cornwall
If you are hitting 110C with 6900XT Asrock Formula? It's got a very bad factory mount. I'd give CS a call and get it swapped.How's it been on the temps. I received mine mid Dec I think but was finding on Performance BIOS (default) and out of the box settings it was hitting 110 and above on the hot spot quickly running Far Cry 6 or after 1 or 2 runs on 3D Mark which was obviously throttling the card. Running an RM850X with three seperate PCI-e cables. Had to switch to Quiet BIOS which kept the temps (Hot Spot) around 100 but not had much chance to mess about it over the last fortnight with xmas and in the middle of adding new mobo and CPU to the system. Got all that sorted with a fresh Windows 11 install over the weekend, so tonight I'm going to have another try tonight but surely temps like that aren't normal running standard settings. I did try undervolting and altering the default fan curve (what a pile of crap that is) but surely you shouldn't have to do that running default settings on default clocks. Case temps and CPU temps have been fine and this is without the side panel on, just not sure if there's a problem with the card, especially seeing the problems with heat regarding the 7900 series.
I decided to turn zero rpm mode off as 1. I can't hear them running anyway at ~880 RPM. 2. I don't like the idea of a warm-ish brick at ~40ºC sitting inside the box just heating other components up around it. 3. With zero rpm disabled the card now idles between 27-30ºC. I'd rather have the heat expelled from the case with the fans just ticking along. I saw no difference in power draw with zero rpm mode enabled/disabled.
. Ever since I swapped from my 3070 I cannot play youtube on my second monitor while gaming monitor without stuttering on the video or both depending on the game. This is with Hardware accelartion on or off, Has anybody else fixed this issue?
