Yeah, I agree with you on that.Possibly an "easy" fix would be to make the newel post caps from wood to match the oak. I think it would tie things together without having to change the whole thing.
Nice work! How did drilling for the posts go?
Out of interest what was bad about the job? At least it'll be a bit easier this time from the extra experience!Regrouted the floor tiles in the ensuite as it was cracking and coming away.
I think slight movement in the subfloor means this is a temporary fix only and I'm going to have to replace the floor
Having just done this in the bathroom and it being a horror job, I'm not so keen to jump into this any time soon![]()
Because the floor wasn't very level due to poorly laid subfloor (lots of small bits of plywood used), the tile cement was laid on very thick. It was hell getting all the floor tiles up and then a nightmare chipping all the cement upOut of interest what was bad about the job? At least it'll be a bit easier this time from the extra experience!
Trade radiatorsChaps -
I need a small "designer" radiator -- 475mm x 600mm (height). Where is a place to get one inexpensively? It needs to be anthracite or maybe a white column rad.
No positives and negativesChaps, how does one put a Hue light here? I just need a positive and negative. Do I just swap the ceiling rose for some wagos?
Seems awfully complicated, lol.
I can swap all of that stuff like-for-like with wagos then? The new light has lots of space to do it neatly/serviceable.Edit: basically, replace the 2 wires going to the bulb fitting, leave the rest in place.
I grabbed two Philips Infuse. Just wanted something out of the way.What hue light are you wanting to put there?
I got this for the kitchen:
Hue Aurelle Rectangle Ceiling Panel Lamp + Dimmer Switch - White | Philips Hue UK
The rectangular Hue White ambiance Aurelle LED panel lamp lets you enjoy warm-to-cool white light with built-in light recipes. Shop now!www.philips-hue.com
