- 28 Sep 2014
- Scotland
What examples are there of TPM being more intrusive as time has gone on? Other than the Windows 11 install requirements needing stuff like it being enabled, but you can then turn off after, I don't know of any consumer apps that must have it as of yet?
TPM has been around a long time and other than a bit of chatter every now and then, it hasn't been a must have enabled thingin anything useful that I've seen yet really?
Community Driven MorePowerTool For AMD GPUs Will Not Support RDNA 3 GPUs Due To Hard-Lock, Users To Pay For Power Limits & Features
It looks like AMD is hammering down on any community-driven tuning applications and options for its latest RDNA 3 GPUs.
Maybe one or the other has read my last post in the MPT thread at Igor, but we, i.e. mainly gupsterg and his contacts, have now come to some conclusions. Of course, Veii has already determined his part, and we actually all agree.
Pretty much everything is double and triple secured. We would have to rewrite firmware and drivers, and we can't do that. Not even under Linux. So there will be no MPT for RDNA3.
AMD really screwed it up this time.
Incidentally, firmware flashing is also controlled via PSP, and we can no longer easily hack AMD software to enable you to flash it. Seems to only work with an external programmer.
This means that you now pay for your power limits and features, you cannot change or activate them afterwards.
Look like AMD gone Apple way with Radeon software now use TPM via PSP for RDNA3 GPUs locked out MorePowerTool to prevent people hacking Radeon software and drivers to gain access to modify VBIOS or attempt to flash modded VBIOS etc on Windows 11 and Linux.
