Sorry, I was talking about hot spot temps, not edge temps. The highest edge temp I've seen with an OC is in the low 70's and the fans are audible but not egregious. When running stock, I've never heard the card fans over my case fans.
Ok, thank you. I'm ok with that. I would probably turn off the Hot Spot temp monitoring in the OSD, i would just find it unnecessarily unsettling seeing temperatures like that when it doesn't mean that much, Nvidia hide that probably for this reason.
And TBH with a 1440P 165Hz screen i was plumbing for the XT, but looking at TPU it is only 15% quicker and for a £100 price difference i'm not sure its worth it.
The RX 6800 None XT is whopping 49% (67% vs 100%) faster than my 2070 Super, i should be happy with that, why stretch my budget so much for another 15 frames out of 100, its still got that delicious 16GB VRam and its not pulling any-more power than my current GPU.
AMD Radeon RX 6800 Specs
AMD Navi 21, 2105 MHz, 3840 Cores, 240 TMUs, 96 ROPs, 16384 MB GDDR6, 2000 MHz, 256 bit
www.techpowerup.com
