- 14 Oct 2007
- newcastle
Apparently the AMD software thinks my card can overclock to 3079mhz
Yeah it'll be close, reduce the power limit on the card and see if that helps.5800x3d, b450 tomahawk max, sf750w Corsair PSU, 4*8gb 3600 MHz crucial ballistix and a red devil 7900xtx
Does anyone have a copy of Hogwarts legacy?
Id be keen to see what kind of power it's drawing and particularly soiking as it's causing my machine to crash completely ( PSU goes click) often just at the shady coming screen and then won't respond unless I switch the psu completly off and on again.
I only have a 750w PSU as mentioned before and was worried it could be an issue. @gupsterg did you say you were on 750w as well?
Seems like a bit of effort though.
True, but for people who may not wanna pay for powerlimit increase via purchase of a higher tier card it's usefulSeems like a bit of effort though.
Yeah "powertune" will do that at times. If you limit FPS it will also do that.Quick question as its a long time since I had an AMD graphics card, does the card only boost to what it needs? As I have just been playing doom and the card was running below its base clock by 200mhz
Sure. https://file.io/7CymmGMSHft9Matt do you mind sharing your Warzone 2 settings. My fps seem to be quite low in comparison. I’m using the 7900xtx pulse.
Cheers buddy, will keep it in mind if i ever get brave enough XD
Reduced it to 90% power limit and no problems.Yeah it'll be close, reduce the power limit on the card and see if that helps.
Now in two minds whether or not to keep the new power supply I ordered or not as I know its likely a problem that will rear its head again in the future.
In general or in Hogwarts Legacy?I’m on a 750w psu. Are you having problems with performance?
In general no. It's tripped in two instances - Hogwarts legacy but that has been fixed by limiting power to 90% and on the cod benchmark when on the oc bios of my red devil.In general.
