Man of Honour
- 23 Mar 2011
- West Side
What does your Dad think of the new pc ?Cheers, I'll have a look. Currently they're 24" so was going to increase to 27"
Very pleased with it, more so once I changed the Rainbow RGB LED display to something more subtle!What did your Dad think of the new pc ?
I wouldn't get b grade monitor just in case there's a dead pixel , but if you don't mind taking the risk then you can probably get it cheaper by making them an offer.Very pleased with it, more so once I changed the Rainbow RGB LED display to something more subtle!
Regarding monitors... There's currently a **B Grade** MSI OPTIX 27" G273QF listed for £280, which seems great value. However, being B Grade is it worth it? They don't appear to list the reason for it being B Grade, and I'm a little hesitant in getting it as a result.
Have had a look at a few reviews on this monitor and something that was raised of one of them was that it uses an unconventional BGR subpixel layout which can result in that text appears somewhat blurry with noticeable red and blue subpixel fringing.I wouldn't get b grade monitor just in case there's a dead pixel , but if you don't mind taking the risk then you can probably get it cheaper by making them an offer.
This is a good monitor but no gsync , if interested check out reviews.
Gigabyte 27" M27Q V2 2560x1440 SS IPS 165Hz 1ms FreeSync Widescreen Gaming Monitor
Order Gigabyte 27" M27Q V2 2560x1440 SS IPS 165Hz 1ms FreeSync Widescreen Gaming Monitor now online and benefit from fast delivery.www.overclockers.co.uk
If you feel that the larger monitor is better suited than go for it but going to 32" the pixel density is lessHave had a look at a few reviews on this monitor and something that was raised of one of them was that it uses an unconventional BGR subpixel layout which can result in that text appears somewhat blurry with noticeable red and blue subpixel fringing.
I already find that the on screen text in Windows and Word etc. not as sharp as I'm expecting and I'm worried that this would only add to this problem. It's strange as I only really notice this on the lighter back grounds, especially in Word, and much less so on darker ones e.g. OcUK Forum blue.
This led me to a possible alternative (Gigabyte 32" M32Q), admittedly larger in size and a little over I was looking budget wise, but a good monitor none the less, if not superior to the 27".
Gigabyte 32" M32Q 2560x1440 SS IPS 165Hz 0.8ms FreeSync LED Backlit Widescreen Gaming Monitor
Order Gigabyte 32" M32Q 2560x1440 SS IPS 165Hz 0.8ms FreeSync LED Backlit Widescreen Gaming Monitor now online and benefit from fast delivery.www.overclockers.co.uk
Would Google 1440p 27" v 32" before you make your decision.
Looks like a good option with benefit of gysync and had a look on Rtings for review which wasn't to bad at that price. It's may be a case of splitting hairs to find the best.Noted... regarding the pixel density and will stay with the 27"
This one offering G-Sync as well: -
Acer Nitro 27" VG272UVbmiipx 2560x1440 IPS 170Hz 1ms FreeSync/G-Sync Widescreen Gaming Monitor
Order Acer Nitro 27" VG272UVbmiipx 2560x1440 IPS 170Hz 1ms FreeSync/G-Sync Widescreen Gaming Monitor now online and benefit from fast delivery.www.overclockers.co.uk
Cheers, appreciate your thoughts and I'll be sure to update my thread in the Monitors section to see if anyone has any thoughts between few that have been mentioned in this thread.Looks like a good option with benefit of gysync and had a look on Rtings for review which wasn't to bad at that price. It's may be a case of splitting hairs to find the best.
My Monitor knowledge is somewhat limited but you could still post another thread in monitor section for further advice before you pull the trigger.
Tag @EsaT in your other thread he's very knowledgeable, I'll check it out later.Cheers, appreciate your thoughts and I'll be sure to update my thread in the Monitors section to see if anyone has any thoughts between few that have been mentioned in this thread.
