- 8 Dec 2002
- North Yorkshire
All Trails
Scanner for what? Also this is a macOS thread, not iOS.Is there a free scanner app out there for iPhone?
You know you can scan to pdf on the iPhone without needing any additional app?Is there a free scanner app out there for iPhone? I could really use one but the subscription model that seems to be haunting every app these days is too expensive. I won’t use it enough to be spending £6 or £7 a month! Any alternatives?
Sorry my mistake , please delete.You know you can scan to pdf on the iPhone without needing any additional app?
But as said, this thread is really for the Mac.
Oh that’s got to hurt. Mine sync to Dropbox or iCloud or whatever they recommend so they’re the same on all my Macs.I rebuilt my Mac due to some issue with Handoff and I forgot to backup my Alfred flows.
I have it all set up right on my work MacBook so I'll check on there when I log in shortly.Oh that’s got to hurt. Mine sync to Dropbox or iCloud or whatever they recommend so they’re the same on all my Macs.
It's not enabled by default so with a bit of luck, all you need to do is set the preferences folder within the Alfred settings and your workflows should re-appear.I have it all set up right on my work MacBook so I'll check on there when I log in shortly.
Is yours syncing with Dropbox, or are you using iCloud? I ask as they recommend not using iCloud, but I really don't want to install Dropbox on both Mac's.It's not enabled by default so with a bit of luck, all you need to do is set the preferences folder within the Alfred settings and your workflows should re-appear.
All very well but it says my free $18 API credit expired a couple of weeks ago.Use ChatGPT from the app.
Urk, does it? It hasn't asked me yet. If it does, it's getting uninstalled.Super Agent for Safari now wants payment, any decent alternates? It works alright, but not well enough for me to pay what they want for it.
It does on my phone, not on macOS (yet).Urk, does it? It hasn't asked me yet. If it does, it's getting uninstalled.
