- 20 Apr 2012
- West Drayton-Heathrow
Hmm I was thinking to get one of these, may hold off a while as not essential atm
				 www.overclockers.co.uk
				What temps you getting, I have a SN850X 1TB as c:\ and its normally between 42-47C and its using the heatsink that came with the MB. Seems hot to me but its my first gen 4 drive.Have added a Heat sink MC1 pro has lowered temps by 20c
be quiet! MC1 Pro M.2 SSD Cooler
Order be quiet! MC1 Pro M.2 SSD Cooler now online and benefit from fast delivery.www.overclockers.co.uk
Thanks, not seen it > 47C so looks like its OK.I have 2tb and 1tb wd sn850. Using my MB heatsink and temps vary from high 30s to mid 40s. I wouldn't worry about your temps as WD rate them as a safe operating range from 0-85C
If the price is good then yes.Thinking of buying a couple SN850X myself, worth buying the versions that come with heat spreaders from factory or not(4TB dont even have a option to buy one with a factory heat spreader on), also do we have to make like a 10%/20% over provision on these drives, i did on my oled ssd drives, thx
Ok cheers, do we need to make a over provision space, or was that only needed on older ssd drives, thxIf the price is good then yes.
If not then add a 3rd party Heatsink.
I think the same rules still apply that the dram cache gets smaller as the drive fills up.Ok cheers, do we need to make a over provision space, or was that only needed on older ssd drives, thx
				 www.neowin.net
					www.neowin.net
				SN850X has firmware issues at the moment, a FW update is planned, no date given by WD.
WD SN850X NVMe SSD that beat Samsung, Seagate, and Hynix is BSODing and freezing Windows 11
The WD SN850X drive, which recently put up great performance against other NVMe SSDs like those from Samsung, Kingston, Hynix, Crucial, is found to be buggy in Windows 11 causing BSODs and freezes.www.neowin.net
