400 MHz over the 7800x3D would be niceCached ccd at 5.4ghz ? That would make it 400mhz over the 7800x3d which would make sense
Hopefully can squeeze some more with pbo / per core optimizer
The loaded cores are running at 5.4GHz. That’s interesting. Possibly the first hint of what the X3D will run at.
Maybe it is the non cached cores at 5.4, seems unlikely that the 3D cores would be at 5.4, could be wrong though.
5.4ghz cached ccd Vs 7800x3d 5ghz to give edge in gaming performance for the 7950x3d
Makes sense they want the highest tier product to be the fastest overall how much by soon to be found out
Well if that is the case it does mean they have artificially limited the 7800 which is not great.
TBH I have a feeling that the 3D cores will not be 5.4Ghz, although as I said I could be wrong.
They would be running at 5.7GHz though. It’s just a screenshot so not confirmation of either. Not long to wait for those reviews.Maybe it is the non 3D cores at 5.4, seems unlikely that the 3D cores would be at 5.4, could be wrong though.
Bit annoying if the 7950 runs at 5.4 and the 7800 only at 5.0, that would mean they are artificially limiting the 7800 to make the 7950 more appealing.
Not necessarily. The chips may be binned for the 7950X3D or not exactly the same.Well if that is the case it does mean they have artificially limited the 7800 which is not great.
This is looking good for tomorrow12900k 81fps vs 7950x3D 136fps
Where is the 12900K result Shanks?12900k 81fps vs 7950x3D 136fps
That is false. The 12900k was using RT, the 3d isn't, since the xtx cannot hit 136 fps with RT on12900k 81fps vs 7950x3D 136fps
Not sure when this is so will be searching every 5 mins in the morningThinking of the launch date I forget that the review date is one day earlier: today![]()
And of course it's a different scene
Not sure when this is so will be searching every 5 mins in the morning![]()
That picture has the second CCD loaded.Well if that is the case it does mean they have artificially limited the 7800 which is not great.
Different GPU's in different scenes plus the 7900XTX was at 92% while the 3090 was at 65% so there really is no correlation to be made whatsoever.12900k 81fps vs 7950x3D 136fps
