Now that is a nice setup!
Debating going Vertical but I will lose on my soundblaster card if I do that ;(
Lol..At first I was amazed and thought "wow thats great". It is indeed a great set up but then I noticed the fans and I vomitted into my mouth. If you are going to go for the noctua look then own it dude , you cannot mix and match noctua and Corsair, thats a crime that even cider cannot save you from.
I used to have a soundblaster.
Most motherboards now have excellent sound capabilities, it's worth the loss.
Cablemod vertical riser bracket and Link Pcie 4.0 riser cable.Which kit did you use to mount the GPU btw?
Nice results but think TopG Matt @LtMatt has cracked 35k on TS with his Nitro...Hi!
So i got my replaced 7900xtx MBA (previous one had vapor chamber problem).
After a week of playing, OC/UV, playing i got so far this:
1065mv | CORE: 3200mhz (max) | VRAM: 2750mhz (FTimmings)| PL +15% | Drivers 23.2.2
A few benches:
Speedway: https://www.3dmark.com/sw/378528
TimeSpy: https://www.3dmark.com/spy/36164552
FireStrike Ultra: https://www.3dmark.com/fs/29613083
I think its possible to get lower UV and higher OC in the VRAM.
Its playable in WZ2 without any crashes or restarts.
Not bad i guess for a MBA.
				Good job they deleted that slide ehis not enough for these thirsty beasts.
i got the 7900 XTX MBA because it was the best perf/price for 4K cards. bought on AMD website for 1135€ while 4080 was sold for 1400€. if the 7900 XT pricing was not as bad i would have took it over the 7900 XTX.Hi!
A few benches:
