OK I went back to my home assistant tonight and figured out the yaml file relationships, debugging the syntax then restarted. It worked. I now have it updating the pvoutput once in the evening instead of polling every 5 mins like some seem to do.
Sorry it was not meant as I don't think you should do it, more so that if all your doing is populating the total generation, date figures - its pointless updating periodically when you can trigger a timer at the end of the evening to do it the once. I am from the back end side of design/dev and reducing pointless traffic is common for work tasks. If that makes sense.
I will prob switch to hourly then as I see it or change my ct clamps going forward (I need one to capture live import), but currently do not have a battery so the statistics are not as plentiful as most of your setups. I do have the eddi but its the older version without built in wifi otherwise I could have hacked that app and stolen more data.![]()
when my new efergy hub arrives i will hopefully be able to send data straight to pvoutput and appear on the live tables as the hub already has the settings to send to pvoutput.....i'm going for hourly updatesI will prob switch to hourly then as I see it or change my ct clamps going forward (I need one to capture live import), but currently do not have a battery so the statistics are not as plentiful as most of your setups. I do have the eddi but its the older version without built in wifi otherwise I could have hacked that app and stolen more data.![]()
Really need to sort out some insulation for the packs next winter at least - was a very cold night and they are currently limited to 25A charge rate which means I’m already exporting a lot… hopefully they warm up soon!
Sorry to say they takes ages to warm up.
Wickes have some good insulation, fire retardant, https://www.wickes.co.uk/Kay-Metzel...lation-Board---1200mm-x-600mm-x-50mm/p/253855
I havent finished mine yet so they are probably 80% insulated but keeps the pack temps far more stable.
The batteries don't generate much heat in reality. Its only the conversion losses in effect and you talking a great big heavy chunk of mainly metals. They really take some heating!
Probably need to insulate the wall behind the packs too as it’s on a single skin exterior wall… definitely on the to do list.
It has stepped up to 30A now from 25A, so slowly but surely warming up a little.
