Finally had a go on our Koda 12 tonight. First time doing dough and using the oven!
3rd one ripped I think that was due to me trying to pick it up and turn before the underside was firm enough.
All started on high and turned down to half once in. Overall went well! Was really nice, none stuck to the peel.
So what about the stone, it's not very black with a fair bit of burned on debris. I see mention that you just flip it and it burns off next time? Is that the case?
Next time I may get a brush to move some debris aside between pizzas. Any tips appreciated! Thankswas fun
Provolone has been nice when I tried it.Getting a bit tired of Mozzarella any recommendations for other cheeses ?
Moz is usually the first ingrediant cooked on the pizza and will often run/melt too quickly, loosing its texture/taste, also seems to have gone up in price disproportionately versus other cheese, like 2x.
Cheddar would go to oil, too easily I guess, but wondering about swiss cheeses like emmental or Gruyere
Made my first pizza of the year. Left the dough too long so ended up rolling it outStill tasty though!
Pepperoni with hot honey is my fave!
Just get plumb tomatoes and mash them up, add what ever else you want.What tomato base is that you used?
I have got the tins from Ooni in the past, but want something easier to get hold of from supermarket.
I just store in the sack it comes in.What do you all store your flour in?
I'm thinking I might get a couple of the 25lt buckets I used to use when brewing beer.
You can add it after cooking, the cooling ricotta goes very well with nduja. Topped with torn basil also after cooking its very nice.In meantime picked up some ricotta, which I'll add near end of cooking time, prepping some lumps ready to deposit.
If you want quick and easy, the Lloyd Grossman sauce they sell in supermarkets is good.
Yup, it should be near the pasta stuff. Probably next to those nasty long life pizza bases they all sell.I will have a look, is it in a jar?
