When I said the 7950X3D gave a tuned 4090 a new lease of life, this is what I was referring to in comparison to everything else out there.
Note: 4090 video was ReBar off as I was testing 4090 Vs XTX with SAM/ReBar off. ReBar on adds another 10-20 FPS for the 4090, so more videos to follow with it enabled soon. It's basically equal to my tuned XTX with ReBar on. I will also add, these 4090 numbers are way higher than anything else out there online.
4090 overclocked with a 13900K
@Grim5 I will put up a 4K video, but I'll tell you right now the 4090 will be completely GPU limited even at 4K lowest settings.
