Thats interesting, but like I said my rift would work but the problem was me losing signal to my monitor (DP) when I start the oculus software. I had only found one similar problem to mine here https://communityforums.atmeta.com/t5/Get-Help/v1-Oculus-rift-nvidia-gtx-4090-no-support/td-p/997851Rift CV1 works fine with my 4090. I plug the Rift into the HDMI and my monitor into a DisplayPort with a HDMI converter.
But sorted now as I have a Rift S for the time being.
So why are you not using the display port on your monitor & using the HDMI/DP converter instead?
I guess £120 isn't a bad price, but, it's such a low resolution headset these days. Not sure what it will be worth in a few months when the Quest 3 is released. You might get £60 for it?
