Home Assistant beginners
Anyone running on docker? Any tips on transferring an existing Pi installation to it? Struggling to get it to restore anything, and no idea what to do with z2m as you can't install addons inside docker container directly
From personal experience as much as I like docker, I wouldn't run HA on it, it just seems such a pain vs a VM.
But with things like Z2M you'll have to run it as an additional container and point HA to it.
Hmm OK, do you use a VM? On windows or linux?
Yeah I use a VM. On the HA site there's premade images for different hyper visors. I run it under ESXi, it's completely hassle free.
OK, I'm such a noob at all this VM and docker stuff (never having used either). RPi works so easily but it's getting slow now I think
+1 for VM, I've got it running under VirtualBox on Linux I think? I threw it together at the time to test HA out and it's been rock solid so left it.
I've never got along with docker for the purposes it's suggested at work either, maybe I'm just behind the times.
Personally for migrations I would just do a fresh install, and then copy over the necessary configs, automations, anything yaml. You'll lose history but at least you'll know it's now a clean working setup.
Ah fair! Is the NUC doing anything else currently? If not then run it bare metal or run a hypervisor on it.
It runs a screen in the hallway which is just HA dashboard.. I'd quite like to retain that functionality as a Pi 3 I don't think will run the dashboard well as it has RTSP cameras showing. Hence my thinking was to run Ubuntu or windows
I’m not a HA beginner by any standard but I need help here! Can someone point me to a tutorial on how to set up HA with a SSL certificate preferably one that doesn’t rely on DuckDNS.
Can someone also confirm that once a SSL cert has been sorted out that homeassistant.local can be accessed over HTTPS.
As you may be able to tell, Ive really got myself tied up in knots with this issue
EDIT: As is often the case, after I requested help, I discovered a fix. In my particular case, although I had all the certs and added the necessary text to the config file, I hadn't cleared the cache of my web browser. I was juggling so many balls and so many tutorials that hadn't picked up this step.
I'm using a NUC with ubuntu for this virtualbox VM, but I can't seem to detect any USB devices (looking for the zigbee stick)
Any ideas?
Is the zigbee stick detected by Ubuntu?
Yeah, all sorted now I think....
Next issue is the WebRTC server app - RTSP stream no longer working on the virtual machine, it was working fine on the Rasp Pi to access my hikvision cameras. It says "WebRTC server not available"
HA very odd sometimes, did a load of uninstalling restarting and it's back to business..
Now the NUC can't handle showing HA dashboard with 4 rtsp streams and running HA (system just locks up) so hopefully some more ram will sort it :/
Got a couple of hours to upgrade my home assistant wall panel today.... :D
Hacked a Fire 10 HD out of its brains to make it a normal tablet, then designed and 3d printed a magnetic cover.
Bit of plastering and it's working nippy quick!
More photos here if interested (need to find a better place than imgur to upload, it's getting harder and harder to just post images!!)
Nice work Katie :)
Not sure if it interests you, but you can rip the battery out of them and wire 5v up to the battery circuit board and run them without the battery to save on any potential issues :) I've done it with two now, a HD10 and a HD8. I figured I'd rather not have the worry of the inevitable battery swelling. And one less fire risk attached to the wall is always a bonus :D
Nice work Katie :)
Great idea Andy! Just as well I've got a magnetic cover!! I might add that to the list!
