Most softeners need two separate exit pipes, one for the waste water from back flushing and an emergency overflow.
To be honest, I’d agree that the evacuation pipe would be classed as foul water and you 100% can’t connect foul water to rain water drains or a soak away. It’s also not an insignificant amount of waster used in the back flushing process either.
You’ll not find a regulation specifically about water softeners but there are quite clear regulations about not connecting foul water to waste water drains (and vice versa).
