Caporegime
- 13 May 2003
- Warwickshire
Hi all
My 2018 car only supports wired Android Auto and I'd rather it was wireless, for convenience basically.
I've recently heard about dongles you can plug into the car that integrate with the factory system and then automatically connect wirelessly to your phone, giving you wireless integration even if not supported by the car.
Do people recommend them, or are they all buggy and more trouble than they're worth?
Thanks.
Thanks.
