New WD black sn850x drive arrived and has sorted the problem, now recognised at gen 4 and getting 7,000 read speeds, sending the 990 pro back. Thanks all for your advice
I guess the last question then is was it a legit item? Presume magician showed the right product? I.e. it wasn't some label switched warehouse return etc?
It's always possible the controller was duff or similar so it could be as you say - a dud. Rotten luck if so.
good shout to check this. Though the mobo and bios manuals are rather poor in explaining which settings to check. OP i would see if there is an online guide or 3rd party help manual.
You should be able to use software to check this; like if it's a Samsung drive install the install the magician software and it can tell of the drive is operating at Gen 4 and if it's x4. There should be other software that can do the same, such as speccy
he knew it was reporting pcie3x4, we were talking about finding a list of which BIOS settings to check to see if something was artificially gimping the slot
@chiefcrust1983
Have you sent the Samsung back yet? I was wondering if reseating the drive would change anything, as the contacts on the M.2 might just have a bit of dirt on them, or the pins on the drive might be a little dirty. Unlikely I know, but it's worth a shot.
