What are you using to check the clock speed? Ryzen CPUs don't necessarily report the clock correctly, depending on the software you're using.
Is your cinebench score vastly incorrect for your CPU?
What about 3D Mark cpu score?
I think the base speed for a 7700X is 4.5 Ghz, but I would be surprised if OCUK ship their PCs out configured to run at the base speed unless you told them to prioritise power/efficiency or use eco mode, or something like that.
Is precision boost 2 / PBO enabled, or disabled?
I restarted the pc which wouldnt restart with different reasons each time - OS doesnt contain the right data and checksums not matching (or words to that effect). Going to speak to OC tomorrow but something isnt right and l think lm at the end of my limited abilities lol. It started in safe mode eventually and lm back on the desktop and you would never know anything was wrong.
