Also try bumping VDDP up to 1.125v.Try putting tCL up to 32 from 30, see if the DIMMs are just a bad bin and rerun the test.
Error count 1 after 11min17sec after changing the tCL.Try putting tCL up to 32 from 30, see if the DIMMs are just a bad bin and rerun the test.
Ok. Cool. I'll try that now. Just saw this.Also try bumping VDDP up to 1.125v.
VDDP prime candidate then. Try 1.125v-1.150v.Error count 1 after 11min17sec after changing the tCL.
To be fair that's also not the values most people use (or what the CPU uses to know when to throttle). The value usually used is the Tdie value(I assume that might be package in your image?) to cite what their CPU is running at. So that might be where some confusion is coming from?Might be down to what he has installed/running, but mine are similarly low on an aircooler (don't think the cooler is the bit making the difference more likely cpu usage tbh).
Error code 1 @ 1.125v 7m12VDDP prime candidate then. Try 1.125v-1.150v.
Nah, try 1.150mv that is the default anyway but I was able to lower mine. If it doesn't work then try to re-enable geardown mode.Error code 1 @ 1.125v 7m12
Do I try to work up to 1.150v in increments of 5. So try 1.130v and keep going until I find stability, but don't go higher than 1.150v?
Thanks! You have the lowest temps I’ve seen anyone report. Anyway, you’ve sent my mind at rest. I was beginning to think something was wrong.Might be down to what he has installed/running, but mine are similarly low on an aircooler (don't think the cooler is the bit making the difference more likely cpu usage tbh).
I'm not sure if this has anything to do with it?Nah, try 1.150mv that is the default anyway but I was able to lower mine. If it doesn't work then try to re-enable geardown mode.
If that does not work either I'm out of ideas. These timings etc have worked for everyone else but you so far. Probably best to just go back to EXPO II profile.![]()
Nah that just applies some pre-defined settings by the board we changed some of those. If you want to go back restore bios default settings, save and exit then enter bios load EXPO II and save and exit and you'll be back to where you were originally.I'm not sure if this has anything to do with it?
It was set to EXPO II not manual?
I'll try what you suggested first, then if all else fails I'll go back to default and load the EXPO II profile.Nah that just applies some pre-defined settings by the board we changed some of those. If you want to go back restore bios default settings, save and exit then enter bios load EXPO II and save and exit and you'll be back to where you were originally.
I tried dude. Short of coming to visit you and do it myself I'm stumped.I'll try what you suggested first, then if all else fails I'll go back to default and load the EXPO II profile.
Thanks Matt.
There's still hope good man.. I'm not at home at the moment, but will give it another go when I do.I tried dude. Short of coming to visit you and do it myself I'm stumped.![]()
I don’t have any issues but have turned off EXPO until we get a new update.
What board do you have dude? ASUS released 1409 BIOS on Friday for the Tuf Gaming X670E Plus, last week just as the reports of burn outs were happening. Not sure if other ASUS motherboards also got a new bios I haven't really checked.I don’t have any issues but have turned off EXPO until we get a new update.
X670e-f gaming wifi. Odd yours starts with at 14. I thought that was the B650 boards. The latest for mine is 1202. It’s just a precaution for me as it seems they have done a quick fix but may not yet fully understand the problem, or at least released an updated that fully addresses it.What board do you have dude? ASUS released 1409 BIOS on Friday for the Tuf Gaming X670E Plus, last week just as the reports of burn outs were happening. Not sure if other ASUS motherboards also got a new bios I haven't really checked.
Yeah.. I've been running EXPO this whole time.
Trouble is I can't get the manual timings to work either without giving me an error when running RAM Test.
