You guys either have low standards or running hardware from the future.Same here, plays great and good fun
Some people are more perceptive to frame stutters and the like.It's clear that many youtube videos are being overly critical as these sort of videos breed clicks and engagement and potentially subscribers. No doubt some are having issues but I'm not.
You said it was broken, he said it works fine. Who to believe… oh maybe the fact it works perfectly for me is what I should believe. Also it cost me £40 from CD Keys for the EA app version.
So not broken and not £60. Was any part of your statement accurate, or are you just repeating the hyperbole? Do you have the game?
It’s not acceptable and people should not be accepting it as if the do it is telling developers they don’t need to do better.Here's how it performs on my 3900X and RTX 3080 FE. Lowering settings makes no difference to the framerate and it stutters quite a lot (I don't think this is acceptable):
HDR seems to work okay, but I haven't got the tools to measure peak brightness so I'm not totally sure if it has the same problem as the Series X (reduced peak brightness).It’s not acceptable and people should not be accepting it as if the do it is telling developers they don’t need to do better.
Anyway how is HDR working for you since you are running the same display 48” C1.
For me it works great as you can adjust both peak brightness and black point.?
Neither do I and I judge it by the eye.It seems to work okay, but I haven't got the tools to measure peak brightness so I'm not totally sure if it has the same problem as the Series X (reduced peak brightness).
If you change any graphics settings you need to restart the game. I’ve had no trouble at all.It’s not acceptable and people should not be accepting it as if the do it is telling developers they don’t need to do better.
I know and it does help to some extent but still having fps drops to low 40s at times, traversal stutter and inconsistent frame pacing no matter how many times I restart the game without touching settings.If you change any graphics settings you need to restart the game. I’ve had no trouble at all.
Interesting that you benchmarked the exact same section as me
For those who want to check and compare HDR in this game, my video is finally available in HDR format.
. You are getting plenty of stuttering like me but at least your framerate is a lot better. What CPU and GPU are you using?Had to limit screen refresh rate to 60hz otherwise GeForce experience would record video at 42fps.Interesting that you benchmarked the exact same section as me. You are getting plenty of stuttering like me but at least your framerate is a lot better. What CPU and GPU are you using?
Do you find limiting it to 60 FPS helps?
Thanks, I wonder why GFE was doing that. I don't think it did that in my case but I have a 120Hz display. No wonder you were getting better framerate than me with those specsHad to limit screen refresh rate to 60hz otherwise GeForce experience would record video at 42fps.
Whether it’s better that way I would say no as while i think some stutters were less visible at 60hz (drop from 60 to 50 is less visible than from 80 to 50) I will take less blurry image that comes with higher framerate but that is personal preference obviously.
I’m using 4090 with 7800X3D.
. Still, you are CPU limited far below where you should be I'm sure.I know your display is 120hz as I’m using exactly the same one.Thanks, I wonder why GFE was doing that. I don't think it did that in my case but I have a 120Hz display. No wonder you were getting better framerate than me with those specs. Still, you are CPU limited far below where you should be I'm sure.
