Kingston Fury Beast 6000MHz CL36
OP
6 Aug 2009
If buying new then the teamgroup memory is better with c30.
Looks decent but a bit more expensive. I'm taking it that there wouldn't really be much difference on an AMD, gaming only setup?
OP
6 Aug 2009
True theres not much difference in performance in gaming, go for the cheaper stuff.
Yes, I've decided to build a "cheap" AM5 gaming machine and move my AM4 to daily driver status. Not much more expensive than buying something to use as a daily driver and keep the AM4 system just for gaming.
Man of Honour
23 Mar 2011
West Side
Presume your pc is in your signature but what's the reasoning in having 2 PC's ?
OP
6 Aug 2009
Yes that's the one. I use my own PC for WFH so needs to be stable, a few VMs running on it. I wanted a dedicated gaming PC so I can play around with it without worrying about corrupting anything or causing myself any grief. I do find it handy for troubleshooting too. I'll move the GPU to the new one and put in something cheap and low power in the old one.
Man of Honour
23 Mar 2011
West Side
So what parts have you decided for the new pc ?
Memory excluded :D
OP
6 Aug 2009
Memory excluded :D
Just ordered a B650 Gigabyte Gaming X AX + Ryzen 7600 bundle for £349. Too good to pass up on! Looking at a Corsair RMx 1000W PSU (planning ahead ;)), drives will be SN770, plenty for gaming workloads.
Man of Honour
23 Mar 2011
West Side
Nice,
Rmx is quality and the sn 770 is a bsast for the money, 2tb for £135 at Overclockers, Tom's hardware did a review on it.
