Looks decent but a bit more expensive. I'm taking it that there wouldn't really be much difference on an AMD, gaming only setup?If buying new then the teamgroup memory is better with c30.
TeamGroup Delta RGB 32GB (2X16GB) DDR5 PC5-44800C30 6000MHz Dual Channel Kit - Black (FF3D532G6000HC30DC01)
Order TeamGroup Delta RGB 32GB (2X16GB) DDR5 PC5-44800C30 6000MHz Dual Channel Kit - Black (FF3D532G6000HC30DC01) now online and benefit from fast delivery.www.overclockers.co.uk
True theres not much difference in performance in gaming, go for the cheaper stuff.Looks decent but a bit more expensive. I'm taking it that there wouldn't really be much difference on an AMD, gaming only setup?
Yes, I've decided to build a "cheap" AM5 gaming machine and move my AM4 to daily driver status. Not much more expensive than buying something to use as a daily driver and keep the AM4 system just for gaming.True theres not much difference in performance in gaming, go for the cheaper stuff.
Presume your pc is in your signature but what's the reasoning in having 2 PC's ?Yes, I've decided to build a "cheap" AM5 gaming machine and move my AM4 to daily driver status. Not much more expensive than buying something to use as a daily driver and keep the AM4 system just for gaming.
Yes that's the one. I use my own PC for WFH so needs to be stable, a few VMs running on it. I wanted a dedicated gaming PC so I can play around with it without worrying about corrupting anything or causing myself any grief. I do find it handy for troubleshooting too. I'll move the GPU to the new one and put in something cheap and low power in the old one.Presume your pc is in your signature but what's the reasoning in having 2 PC's ?
So what parts have you decided for the new pc ?Yes that's the one. I use my own PC for WFH so needs to be stable, a few VMs running on it. I wanted a dedicated gaming PC so I can play around with it without worrying about corrupting anything or causing myself any grief. I do find it handy for troubleshooting too. I'll move the GPU to the new one and put in something cheap and low power in the old one.
Just ordered a B650 Gigabyte Gaming X AX + Ryzen 7600 bundle for £349. Too good to pass up on! Looking at a Corsair RMx 1000W PSU (planning aheadSo what parts have you decided for the new pc ?
Memory excluded![]()
), drives will be SN770, plenty for gaming workloads.Nice,Just ordered a B650 Gigabyte Gaming X AX + Ryzen 7600 bundle for £349. Too good to pass up on! Looking at a Corsair RMx 1000W PSU (planning ahead), drives will be SN770, plenty for gaming workloads.
They look very good for the money. Hoping I can move my AIO to the new one and use the AMD cooler on the 5800X3D in the short term but the Assassin would be a nice cheap option.@Troezar
Forgot to add if your in the market for a new CPU cooler the Thermalright Peerless Assassin 120se is the best value to performance king.
but Kingston also sell 32gb kits of 6000Mhz cl30s these days?
Yes as per my signature. Runs very well, had to move to a 360 Arctic Freezer II, which is overkill for the 7600 but gives me some upgrade potential. I'll drop an 8800X3D in eventually, assuming they release one.
