Looking at building new AMD system, is the problem only with 3d chips or is it rest of AM5 chips as well ?
The problem has been found with non X3D chips.
I don't recall it being in the media until it started happening with the X3D chips. If it did happen, it was quite a small number.The problem has been found with non X3D chips.
It's still quite a small number when you think about how many chips they sold, I think it was first noticed when the first 7800X3D went pop, then everyone started checking their chips, it just a big thing because let's face it, if it was just 1 they would probably just brush it under the carpet, but as it's a few it's made headlines in the tech world, and become something that must be fixed, I'm sure AMD and board partners don't want to have to eventually replace everyone's CPU and motherboard.I don't recall it being in the media until it started happening with the X3D chips. If it did happen, it was quite a small number.
I'd run it all stock - not OC'ing. I've rolled back all my Mem and CPU clocks till they have either fixed via BIOS code or decided they need to take other action.I've got an Asus X670E extreme and 7950x3d build almost finished, just need to pressure test and fill the loop...
What should my steps here be? Obviously update bios is number 1 but is there anything I can do to limit the scope of failure? Can/should I manually set the various voltages?
Also, if the board or CPU do die because of this, presumably OCUK will handle the replacement and I won't have to go through AMD/Asus?
We'll look at it this way, I'm running an Asus board with a 7900 and I'm using overclocked settings on my ram, granted I've hard set my voltages but it seems this isn't enough, however, me along with a shed load of other people are still using our systems, we've not just switched them off and put them away in a cupboard somewhere to collect dust until the issue is fixed, so really it's up to you, but there's a lot more working chips than there is killed chips.As someone planning to build a new PC today with a 7600X and MSI B650 board, I'm a little worried although it does seem to be a bit more prevalent with X3D CPUs and Asus boards. Would you guys think I'm likely safe with these and leaving everything stock? I imagine the safest advice is wait until a new bios comes out that's out of beta etc. although I have a pile of parts sat there ready to be built and I'm very keen to do it. I'd been reading about all this the last couple of days but previously thought it was only the new 3D CPUs with the issue until now.
My advise, flash to the latest BIOS and leave at stock. Or wait till Friday and flash the 'fixed' BIOS then - if that really does fix it.
Rumour mill = fixed bios release. Take with a pinch of salt.What’s happening Friday?
Seems like the X3D chips are more fragile though. I was considering upgrading to AM5 with the 7800X3D but this has put me off, I'll probably wait until Zen 5 now with rumors it will be released early next year.The problem has been found with non X3D chips.
)I'd personally run the EXPO profile (assuming your ram has it), and just manually set SOC. Alternatively if you set everything to do with your ram manually then you don't need to change any voltages (aside from DDR).I've got an Asus X670E extreme and 7950x3d build almost finished, just need to pressure test and fill the loop...
