Ukraine Invasion - Please do not post videos showing attacks/similar
Status
Not open for further replies.
Punishable by fine, unlike theft of a sheep which was a jail-able offense, this is where the English belief that Wales was a nation of sheep violators came from. Because they were forever catching Welsh people attempting to steal sheep, who claimed to just be trying to violate them (seriously not a joke, that's where that originated from lol).
:eek:
Place your bets that no one will ever give up `the bomb` once they have them again. Granted only South Africa did, but no one else ever will now (and more will go further to get them)
IIRC, nobody at the time knew South Africa had the bomb, so when they announced that they’d given them up, it was initially met with confusion.
Maybe, one possibility is that he's not playing there/not bluffing and is genuinely kicking up a fuss because he wants more support/more ammunition.
Perhaps he is making a power play/aiming to replace Putin after the war when it's acknowledged in Russia what a huge **** show it was.
Another possibility, given he seems to be the only powerful Russian confident enough to speak out like that is that Putin really is very ill and is setting him up as his successor.
US intelligence is claiming he has significant ammo stockpiles just lacking some heavier weapons. Probably suits Putin to have him there bogged down in Bakhmut grinding Ukraine's forces even at large losses for Wagner but Putin doesn't seem to be capitalising on that with increased mobilisation and pushing elsewhere, etc.
Can anyone substantiate this re
"The Washington Post writes the UK will send long-range missiles to Ukraine, with a range of 300 km U.S. officials who spoke to NatSec Daily say Biden hopes it will silence critics who want the US to send ATACMS to Ukraine, arguing they are off the hook thanks to the UK's plans."
Or is the WP the US' version of The Daily Mail..
AFAIK it is referring to this: https://www.gov.uk/guidance/international-fund-for-ukraine-ifu
Long range strike - closed on 4 May 2023, 23:00 BST​
EOIs were requested in the following sub-capability areas:
Missiles or Rockets with a range 100-300km; land, sea or air launch. Payload 20-490kg.
Desirable requirements:
  • Low Probability of Intercept (LPI)
  • Includes Mission Planning Capability
  • Assured navigation (with hardened Global Navigation Satellite System capability) in the face of advanced countermeasures and EM spectrum denial
  • Air defence penetration methods to increase probability of successful strike
  • Technical Readiness Level of at least 8
Suppliers who submitted an EOI will be contacted from 5 June.
Unless someone has something basically ready to go just needs a bit of funding for final tweaks and production seems a bit useless to me as nominally it would take around 2.5 years at an expedited pace for contracts to be hammered out and development and testing, etc. before production even starts.
The only way that would work was if the warhead was literally on the core and even then it still wouldn't do much to the fuel, the problem is that it would create a massive cloud of radioactive isotopes (most of which won't survive very long) that could just as easily flow over Moscow or Putin's favourite hidey hole and I highly doubt Beijing would be remotely happy.
Way too many negatives for Russia especially since it would be obviously their fault.
Nuke bomb does NOT equal nuclear reactor. (Unless they nuke the reactor)
hiroshima - rebuilt in 2 years, population returned to pre bomb in 13 years. No lasting radiation..
bomb has 1kg of uranium..
reactor has 1000kg...
The thing with Chernobyl, which I see a lot of people miss, was the explosions and runaway burn off fuelled by material on site allowing a massive amount of toxic and radioactive material to be spread - pretty much any newer built reactor has been changed to prevent those scenarios happening like Chernobyl and nuclear bombs as you touched on don't work like that - many 100s of atmospheric nuclear tests have already occurred. Some nuclear bombs can have 100s of even 1000s of kg of stuff like uranium in them but what happens when they detonate gets hugely complicated and I'm certainly not an expert on it - but a lot of it ends up as short lived isotopes.
One of the bigger issues with nuclear bombs is if they are large enough and used in way and situation which causes massive firestorms, but that isn't so much about the radiation/fallout.
They did know , in 1977 the US, USSR and French governments all knew, and it was even in the media:
Bigger nukes use a fission reaction to generate a fusion reaction and will not be using much more fissile material than small bomb. In castle bravo it was 400kg of lithium 6 yielding around 15megatons.
The issue is when you strap cobalt to the nuclear bomb then simply detonate it high in the atmosphere, irradiating an entire continent making most, if not all of that continent uninhabitable.
The main problem with fusion is the supply of tritium. Its one of the questions being asked about the Soviet stockpile of weapons - have they replenished the tritium at all, because by now it would have decayed (1/2 life is 12 years). Its also why its stupidly expensive, about £30,000 per gram.
Clearly a reaction to the number of people expecting spoilers for the date of the counter offensive.
It's as if people treat this as entertainment, and think the plot should be simple and predictable.
You can see by some of the posts here that for some, this is entertainment. Meanwhile, hundreds of people on both sides are dying every day.
I see India has saved themselves £4bn since the invasion through purchasing Russian oil. They have went from 2% imports of Russian oil to 20%
Kneejerk reaction but why should the UK continue to give aid to India, a country that not only will not condemn the invasion of Ukraine but actively supports it happening by purchasing vast amounts of Russia oil.
When at uni i wrote an essay about the myth of the `peoples war` and the blitz. Sadly exactly the same opinions happened then as it does now - unless you are under direct attack, no one cared. April 1941, one of the heaviest bombings of London, in Sheffield there was a miners strike (not sending coal to the south), in Eastbourne they were worried about drunken soldiers and in Blackpool it was the `season` and the best ice cream parlours.... in fact a lot of the press photos (milkman on his round, woman drinking tea) were all staged.
Is it really aid? Or is it bribes?
Status
