Don
- 20 Oct 2002
- Oxfordshire / Bucks
The initial one I bought was second hand, and it ended up kind of breaking where it would run the pump every few seconds when not in use to almost prime itself. When I first bought it, I would do this, but only every few minutes. Since buying a brand new one, the machine doesn't try and prime itself except from first setup so I can only assume the initial second hand one was on its way out anyway.
It's a chunky unit though, you can place the green base unit into the black bucket but it requires unscrewing the M22 hose to do so. The hose is very hard to screw onto the output though, and it's a complaint I've read about these where people have ruined the threads on the output because of how difficult the hose is to remove.
Thanks for your reply
to be honest i think what i will do is leave it with the bucket ontop as is and when i go out to clean the car i can shove stuff in the bucket like a jerry can of water out to the car which is parked over the road that requires a little walk to get to
if you were thinking of taking the base completely apart, i wont be doing that anyway lol
do you use the MJCC foam cannon with it ? what parts do i need ?
