ITX upgrade - critique my build
23 Apr 2012
Edinburgh
Currently I'm running an mATXbuild from 6-7 years ago - 7700K/Asus Z270G/1080ti and an AIO and it's time to pass this to my son and build a new one for myself.
To be honest I play far less games than I used to and no longer have the time to tinker with overclocking much so don't need a top level board any more, but the few games I do play need to be 1440p and I want to leave myself open to "treating" myself to a decent card in the future. I have a "spare" 1080ti which I'm going to use until funds allow, at which time I'll probably be open to CPU upgrade if needed. I think this CPU will be ok up until a 4070 though?
My basket at OcUK:
Total: £1,057.90 (includes delivery: £0.00)
Comments please?
CPU is fine and overall the system is good and has potential , no drive m2 in the list ?
For an extra £20 think I would up the psu to the 1000w version.
It might be advisable to reconsider your choice of motherboard. It's dumb that some ITX motherboards have a very small chipset and/or vrm fan. From previous research, I learned these small fans could be rated up to 20K hours at 40c whereas at 60c or 80c they start to fail a lot quicker resulting in an annoying fan whining sound.
I don't know the model of fan in the Asus B650-I, however, it looks likely to be the 30mm fan they've used in previous motherboards.
I stopped using my Asus B550-I a few weeks after upgrading to a 5950X. It was only ~10 months old at the time and before the upgrade the fan usage was estimated to have been only a couple of thousand hours. The VRM temps were hitting 60+ and sometimes 80+ with the 5950X at full load and soon the fan noise became unbearable. The fan was running at up to 9K+ RPM and after a few weeks of using the 5950X the annoying whining sound started.
I have my watercooled ITX PC running virtually silent in light/medium use and at load I prefer only "airflow sound" which I guarantee by buying quality 120/140mm fans that don't produce motor whine.
I'm sort of second guessing myself now you've reminded me of chipset fans - I'd rather not have chipset fans at all and went AMD as I want to keep overall TDP/Heat low too to give lots of headroom to air cool (current system is AIO and I want something a little more maintenance free), but there are very limited options for AM5 ITX.
I'm still using AM4 and I had an old Gigabyte B450 ITX board I could use. Historically, it appears they over-engineer their ITX boards to not require a VRM fan with better VRM phases design and bigger VRM heatsinks.
The main thing when deciding on a board is to read reviews to ensure there isn't a hidden tiny fan and I would suggest looking at Gigabyte's offerings. I'd be surprised if their AM5 ITX boards weren't over-engineered in the VRM department although it could happen, just look at Asus, one would expect them to over-engineer to prevent the use of VRM fans especially with their supposedly top of the range boards but evidently they dropped the ball a long time ago.
I am looking into buying the EK monoblock for my Asus B550-I, as I can then watercool the VRMs, chipset and CPU. Then I can remove the VRM fan. The EK block isn't fully compatible with the Asus B550-I, it's designed for the Asus X570 ITX board, but the design is close enough that I can get it to work, I'll have to uninstall the top M2 slot and the audio connectors, but it'll be worth it. :D
I contacted Asus asking asking for a couple of their VRM fans so I could get the board back up and running, but the answer was they don't stock parts and I needed to go through the retailer. I looked into the RMA proccess for Asus and the retailer so I knew what I was getting into. I tried to communicate with the retailer (not OcUK) but they weren't interested in a conversation. Also, the evidence of how badly the retailer supports their customers is all over the internet, so I gave up. Maybe in the future I would take the time to show them how to provide better customer support but I'm too busy to have a project like that and it would stress me out too much.
Yeh, the Gigabyte boards seemingly have their own issues too though. Strange Asus didn't want to send you a fan - there's literally a video on YT where the guy emailed asking for and got sent one.
To be honest, I'm thinking maybe just spend the extra and get the ASRock offering with a 7600X - I can't see fans anywhere on their design except the M.2, which I can just leave off or replace with a heatsink instead. It's not going to be overclocked, I just want something trouble free for the next 5-7 years with a CPU upgrade path should I need it.
Reading a review on the Asrock motherboard it mentions lowering the tj max settings to 85°c to keep the vrm in check.
My basket at OcUK:
Total: £1,057.90 (includes delivery: £0.00)​
Comments please?
Any particular reason you're getting the older A4 instead of the A4 H20 case for cheaper?
Because I have a RTX 4080 I was considering the cases below.
Dan C4-SFX
Cooler Master NR200P MAX
I went with the Cooler Master as I like the pre-installed AIO + PSU as I've recently built 2 NZXT H1 v1 cases.
Also I went with an Asrock board because of the eDP port which I will have play with using Asrock's LCD panel kit:)
Also consider the NZXT H1 v2 as it's down to £229.00 with AIO + PSU
Also there's a P200A in the B grade section. I always look there first myself for a basic case as I've not had any issues with the 4 I've had from there.
This is my first DDR5 build and what I learned is the stated speeds aren't certain to work out the box even if the parts are on the relevant QVL lists.
£240 (incl. VAT)
£170 (incl. VAT)
£350 (incl. VAT)
£275 (incl. VAT)
That's interesting, which YT video? I've seen other AM4 ITX board manufacturers like ASRock have provided free replacement small chipset fans but not anything about Asus yet.
I completed my Dan C4-SFX build last week but went down the Intel route.
Currently running a Intel 13700K cooled with Noctua D12L, Asus B760i Mobo (only ITX mobo I have found without a fan) and RTX 4070 FE.
Really happy with the build as its silent in low to medium load and pretty quiet even when everything is stressed during synthetic benchmarks.
