- 21 Apr 2007
I might try experimenting by creating a second CV which contains only acronyms and some basic stuff - just so it hits all of the searches, to see if it makes a difference
It feels cheap AF, but... I don't see what else I can do..
Reddit - Dive into anything
Here is some inspiration for your new CV, just be sure to put Mia Khalifa under your skills section and you'll be golden, that coding language is so hot right now....
On a more serious note, i'm pretty sure you can find a way to weave more of those types of buzz words into your CV, you should give it a shot and see if it makes a difference.
