Hello,
I've been having a problem running games on a new PC build..
I'll launch a game (e.g. Starship Troopers) and will be able to play for a couple of minutes; then the game will crash. The system will either return to desktop, or restart.
As starship troopers is running Unreal Engine, the error thrown from there is a "Device was removed" error.
In windows event viewer, there are one of two errors that are logged at the time of each crash.
NVIDIA OpenGL Driver:
DrvSetContext failed functionality indeterminant
(pid=14656 cncmd.exe 64bit)
And
Ran out of memory
I initially thought it could be a heat issue, with the card shutting itself off, but the GFX card doesn't get above 40c.
Rolled the dice on a B Grade graphics card; but perhaps this is the problem?
Any suggestions of things to try would be appreciated. I have time today to test anything suggested.
edit: Also tried turning the games graphics way down, but still experiencing the same problem.
After the game freezes, it will hang for a good minute, then all the colour will dissapear from the image, leaving it looking like so:
This will remain on screen for another 10-20 seconds, then the PC will either crash to desktop, or restart.
And
Ran out of memory
