Demand destruction and reducing money supply. It is a way.That is ****.
Basically not a way to sort out inflation
That is ****.
If you have an interest only mortgage of £223,000 on a property valued at £475,000, how much do you own exactly in percentage terms?
But as I said, if u work in the entertainment business u will lose your job
I can’t work out exactly, but I know it’s around 50%If you can't work that out you probably shouldn't be eligible to have a mortgage in the first place![]()
Other way around. Mortgage is 223. Not how much own.46.94736842105263% is as close as I can get it
Thanks. 53%You own (475-223)/475*100
Like its that easy?Find another job
I wanna renovate my house!You can take my pub visits. You can force me to stay in my Peugeot 207 automatic.
You can make me live with my 46in plasma 5 more years....
But you'll never take my international adventures!
(besides.. Its mainly funneling money out of the UK!.. Take that tories!)
I'll keep my cleaner too thanks!
Yea anything house related is absolutely bonkers.Too expensive! Wanted to get ensuite done. Then I saw cost!
Probably one of the biggest rises that sort of stuff.
Drill hole through wall and use a hose pipe. Assuming you can afford water bills.Too expensive! Wanted to get ensuite done.
